** PHANTEKS ENTHOO PRIMO - THE ULTIMATE WATERCOOLING CHASSIS **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
As many of you are no doubt aware from previous threads I have made, I am rather excited about the debut case from Phanteks.
The Enthoo Primo is the first case from Phanteks and has the enthusiast community very excited.
The case features new and innovative design features which you will not find on other chassis. The case has an obscene amount of watercooling potential and is the first case I can remember having reservoir and pump mounting hardware as part of its base spec.
I am aware that this ultra premium case may not be for everyone, but I am positive that every hardware enthusiast on here will see the potential of this and looks forward just as much as I do to the inevitable stream of multi GPU, watercooled monsters that this chassis release will spawn.
Our stock is due to arrive soon and we will have excellent allocation.
In the meantime, check out these preview videos that give a brilliant overview of the Enthoo Primo:
Gallery:
Top
Rear CM points
Pump mounting Brackets
SSD Mounting
Front Reservoir Bracket
Rear Reservoir Bracket
Pump Brackets
Case Rear
Pump Mount
Alternative Pump Mounting Locations
ODD Positions
PSU Locations
Case Plaque
External Shots
HDD Position One
HDD Position Two
IO Ports
Side Shot
Front Fans
Front Brushed Alu
Bottom Brackets
Air Filters
Case Floor
Case Floor Filters
Example Build Pictures
Phanteks Enthoo Primo Full Tower Case @ £199.99 inc VAT
The bar has been set to a new standard with Phanteks’ release of their first Enthoo series case.
Passionate about cooling and the one that brought you the world’s best air coolers, Phanteks enters
the case arena with their functional design with exceptional cooling possibilities, the Enthoo Primo.
Accessibility and functionality is what sets the Enthoo Primo on a level of its own. It was constructed
from a builder’s point of view with the closest attention to detail. This Enthoo Primo combines innovative
design and rich styling that appeal to builders of any caliber. A glimpse through the split window side
panel reveals the clean interior, capable of being water cooled, air cooled, or both.
Phanteks’ Enthoo Primo, unleash unlimited possibilities.
Specification:-
- Colour: Black / Blue LED
- Form Factor: Full tower
- 5 Phanteks’ PH-F140SP premium 140 mm fans included.
- Material(s): Aluminum faceplates, Steel chassis
- Motherboard support: ATX, EATX, mATX, SSI EEB
- Front I/O: 2x USB 3.0, 2x USB 2.0, Mic, Headphone, LED switch
- Side window: Yes, split-window design
- Expansion slots: 8
- Power Supply Slots: 2
- Dimension: 250(W) x 650(H) x 600(D) mm
- Warranty: 5 years
Driver Bays:-
- External 5.25” 5
- Internal 3.5” 6 (2x 3HDD cages)
- Internal 2.5” 12 (2x 3HDD cages + 2x doublestack SSD brackets
*expandable to 3x)
Cooling:- 120mm
- Front: 2x
- Top: 4x
- Side: 2x
- Rear: 2x
- Bottom: 4x
- HDD: 2x
- The PWM hub will enable PWM function to 3-pin fans. Total of 11 fans can be connected to the PWM hub.
Extensive water cooling support provides 5 different installation areas for slim and thick radiators varying from single to quad (120mm and 140mm form factors) with clearance for push-pull fan configurations.
Liquid Cooling Features:
- Reservoir Brackets
- Pump Bracket
Radiator Support:
- Front: Up to 240
- Top: Up to 480 or 420
- Side without HDD Cages: Up to 240
- Rear: 120 or 140
- Bottom: Up to 480 or 280
Clearance:-
- CPU cooler 207 mm
- Cable management 30 m
Only £199.99 inc VAT.
ORDER NOW
10 Feb 2007
Certainly looks the part - be interesting to see how this stacks up with the Corsair 900D and be interesting to see if they bring out some less expensive cases to market.
Mei
Mei
3 Jan 2012
i really thought these would be way expensive
looks very good value!
hope they making some profit i want see more cases from them
i want a matx phanteks ><
20 Jun 2013
pity I'll have to move that central resevoir holder to fit my card in
Edited:
Nope enough room apparntly for my evga gtx 770 and a 60mm Tube res on the central mount.
1 Jul 2011
[In Depth Review by MNPCTECH] Phanteks Enthoo Primo: The Ferrari FXX of WC Casing
Just watched the 48 minute MonsterMawd video review. Bill of Mnpctech and Jesse from The Mod did a great job!
I much prefer written reviews to videos but they did an outstanding job of showing us the Enthoo Primo!
Jesse is doing an in depth custom loop review on The Mod Zoo website too... HURRY UP JESSE!!
Really want to get my hands on one and test out it's great air cooled capabilities.
http://www.youtube.com/watch?v=CIpoC65bpX4
