** PHANTEKS EVOLV ATX GLASS - MAKING A GREAT CASE EVEN BETTER **
OcUK Staff
26 Nov 2014
Stoke
Finally, I can unveil the wonder that is the Phanteks Evolv ATX Glass to you all. Phanteks have taken the impressive Evolv ATX and added a pair of tempered glass side panels, RGB LED functionality and connectors for a pair of Phanteks LED strips (sold separately). The RGB functionality has been improved from previous Phanteks cases, now any connected Phanteks LED strips (including the front power light and top button) have 3 modes - Static, Pulsing and Colour Cycle, allowing you more LED customisation without the need for an aftermarket upgrade. They are also fully Asus Aura compatible if you use the Phanteks motherboard RGB LED adapter.
The end result is stunning. It is so impressive that it prompted me to upgrade from my Evolv M-ATX to an ATX X99 setup and build into an early build sample we were sent. I've been very privileged to have this as my case for the past few months and I am glad you will all get a chance to get one too! Probably the thing I like the most is the fact that both panels are tempered glass, so your cable management game needs to be on point (which is partially the reason I aren't going to share my absymal attempt, although I do have some braided cables to add which should make the job easier :))
Stock is available in Black, Gunmetal Grey and Silver, and will be available around the 2nd week of May. Preorder now, initial stock is pretty tight!
Phanteks Enthoo Evolv ATX Glass Mid Tower Case - Black @ £154.99 inc VAT
Designed based on the EVOLV line, the Enthoo EVOLV ATX Tempered Glass Edition combines sandblasted aluminium with tempered glass panels. System builders and watercooling enthusiasts can now present their build with a premium touch. The EVOLV ATX Tempered Glass Edition is equipped with innovative features, amazing (water)cooling potential, and RGB illumination.
Addressing the online community’s desire for the ATX version of the Enthoo EVOLV case, Phanteks have released the new Enthoo EVOLV ATX to the EVOLV series. A premium mid tower chassis with an aluminium exterior with minimalistic design based on the original Enthoo EVOLV. The EVOLV ATX features the quick release side panel system, innovative top radiator bracket, and the new HDD mounting system.
Like the EVOLV, the EVOLV ATX retains the full 3mm thick aluminum outer panels with the quick release system. With the EVOLV series ranging from mini ITX to micro ATX, the EVOLV ATX features a large interior to support full ATX systems. Unleash unlimited possibilities with the Enthoo EVOLV ATX.
Features
- Aluminium body (3mm thick)
- Clean interior - Hidden PSU and HDD’s
- RGB LED Illumination - 10 different colours
- Retractable Radiator Bracket - Convenient Installation
-Tempered Glass Sidepanels - Show off your system build with style!
- Quick release panels for easy access
- Equipped with 3 x Phanteks PH-F140SP 140mm Fans, PWM Hub, 35mm Cable Management Space and Phanteks Velcro Ties + additional cable compartment in bottom.
- Bottom and Front Dust Filters
- 2 x SSD Brackets Included
- 3 x Modular 3.5" HDD Bracket included
- Watercooling ready with Reservoir/Pump Mounts and space for up to 360mm radiators on Top/Front Panel
Specifications
- Dimension: 235 mm x 495 mm x 510 mm (W x H x D) 9.25 in x 19.5 in x 20.1 in
- Form Factor: Midtower
- Colour: Satin Black
- Material(s): Aluminum (3mm), Tempered Glass (4mm), Steel chassis
- Motherboard support: E-ATX *(up to 264mm wide), ATX, Micro ATX, Mini ITX
- Front I/O: 2x USB 3.0, Mic, Headphone, RGB LED control
- Side window: Yes, tempered glass panels (left & right)
- Expansion slots: 7
- Internal 3.5”: 8x (5x included)
- Internal (dedicated) 2.5”: 3x (2x included)
- Air Cooling Support: Front - 3 x 120mm, 2 x 140mm (2 included) , Top - 3 x 120mm, 2 x 140mm, Rear - 1 x 120mm, 1 x 140mm (1 included)
- Liquid Cooling Support: Front 120mm - Up to 360mm, Top 120mm - Up to 360mm, Rear 120mm - 120mm, Front 140mm - Up to 280mm, Top 140mm - Up to 280mm, Rear 140mm - 140mm
- PH-F140SP Included Fan Spec: Speed (rpm) - 1200 ± 250 rpm,, Max Airflow: 82.1 CFM, Static Pressure - 1.33mm H2O, Acoustical Noise - 19dB
- Graphic card clearance: 420 mm (16.54 in) No HDD brackets, 300 mm (11.8 in) HDD brackets installed
- CPU cooler clearance: 194 mm (7.6 in)
- Cable management: 35 mm (1.38 in)
- Memory clearance (motherboard - fan): 120mm: 68 mm (2.68 in) , 140mm: 48 mm (1.89 in)
- Model: PH-ES515ETG_BK
- Net Weight: 13 kg (28.0 lbs)
- Gross Weight: 16 kg (35.5 lbs)
- Package Dimension: 324 mm x 590 mm x 577 mm (WxHxD)
- Warranty: 5 Years
Only £154.99 inc VAT.
ORDER NOW
Phanteks Enthoo Evolv ATX Glass Mid Tower Case - Gun Metal @ £154.99 inc VAT
ORDER NOW
Phanteks Enthoo Evolv ATX Glass Mid Tower Case - Silver @ £154.99 inc VAT
ORDER NOW
18 Jun 2005
I always avoided side windows over being acrylic and even cleaning the dust off with even a micro fibre causes light scratches. Now that we have tempered glass I will definitely go for this. I love everything about this case.
30 May 2015
Sussex, UK
In honesty, as long as you have the case in a sensible position I don;t see why it would get scratched. It's not like a phone that is constantly in and out of pockets etc.
3 Aug 2006
It is a beautiful case, it's just a shame that like the standard version it's beauty has to come at the cost of either a hotter or noisier system than you could build in the Structurally similar but differently skinned Pro M :(
18 Jun 2005
I'd love tempered glass on left and solid side panel on side. But that's me. In any case I will definitely be getting one of these.
Out of curiosity I assume it can handle a h110i in the roof ? and how does that work with regards the phanteks pwm controller.
The reason I ask is because Corsair say to connect the 3pin pump rpm connector to the CPU_Fan power connector (only used to report pump rpm speed). The power for the pump goes to a sata, and the 2 x 4pin pwm fans plug into the pump directly.
While my understanding is that the Phanteks pwm controller only takes 3 pin fans, and it's power and speed regulation comes from the CPU_Fan power connector.
I am assuming you can just power the Phanteks pwm controller from an alternative (aux) pwm Power connector on the motherboard ?
18 Jun 2005
Iirc when I used to use mine on the luxe it needed to go on the CPU or CPU alt header.
Thanks. Sounds like the CPU alt header would be best option for pwm controller.
Must read some more reviews before pre-ordering but I have heard people complaining that the Evolv can be a bit of an oven which isn't surprising with those slots on the top and front. But I will only be lightly overclocking either with a H110i on silent mode in roof or possibly a good air cooler. I assume the GPU cooling is sufficient from the front fans. I know those Phantek models are considered some of the best. Concerned the lack of direct airflow might be an issue though.
18 Jun 2005
Well determining which one is nicest is hard unless you see them in the flesh. The silver looks like it's a new colour for the glass version. To me it looks a little bright. But thats just a photo. So who knows. The black is probably the safest bet.
