OK folks, in light of the competition currently running to win yourself your very own S340, I thought it would be good to create a post for those that have already experienced, tried and tested. Feel free to throw in pictures of your rig, comments, upgrade questions or problems. I would be more than happy to help!
The full lowdown on the kit is as follows:
- 360° of steel casing surrounding the all-steel chassis
- Grommet-less cable management bar keeps cables tidy with ease
- Full 280mm radiator support for the latest Kraken coolers
- Compact form factor coming in two inches below competing mid towers
- Detailed design and engineering with tons of small touches
- Very easy to build in for new and experienced users alike
- Integrated PSU shroud for an ultra clean build
- Fully filtered intakes
Drive Bays
External 5.25": 0
Internal 3.5": 2+1
Internal 2.5": 2
Cooling System
Front: 2x 140/2x120mm
Top: 1x 140/120mm (1 x 120mm FN V2 Fans Included)
Rear: 1x 120mm (1 x 120mm FN V2 Fan Included)
Filters
Front (Included)
Bottom Rear(Included)
Radiator Support
Front 2 x 140 or 2 x 120mm
Rear 1 x 120mm
Clearance
GPU Clearance With Radiator: 334mm
GPU Clearance Without Radiator: 364mm
CPU Cooler: 161mm
Cable Management: Lowest Point - 17mm; Highest Point 168mm
Dimensions
200mm x 445mm x 432mm
Material
SECC Steel, ABS Plastic
Motherboard Support
Mini-ITX, MicroATX, ATX
Expansion Slots
7
External Electronics
1 x Audio/Mic
2x USB 3.0
Product Weight
7.05 kg
USB 3.0 Ports
2
Warranty
2 Years
CA-S340W-B1 (Black) - £59.99inc.VAT
CA-S340W-W1 (White) - £59.99inc.VAT
