OcUK Staff
We're pleased to announce the launch of a new gaming chair brand - Vertagear. Vertagear’s main focus is on comfort and adjustability. Vertagear understand that gamers tend to ignore the importance of a chair when sitting in front of a computer and often lose the sense of time when playing their games, generally resulting in back pain and neck pain. One chair does not fit all, this is the reason why Vertagear designed chairs to accommodate different type of users.
The desirable S-Line series is designed with the basis of ergonomics and adjustability as the main feature of the chair. All models have one thing in common and that is to give a wide range of adjustability and flexibility to gamers.
Each model has a different aspect that is unique in design to satisfy different type of gamers. Not everyone is the same, this is the reasoning of each model and why it’s important for a chair to be right for the gamers. Features like 170 degree recline, ergonomically designed armrest that is cushioned and contoured to the shape of the arm, height adjustments, lumbar support and many other features that makes the Racing series a right choice for gamers. Vertagear’s Racing Series S-Line gives the gamers the options to define which model is right for them.
Vertagear have 3 current series, the SL-2000, SL-4000 and SL-5000. Having checked out and sat in one of these myself recently I can say they are very comfortable, extremely sturdy and very feature rich. These will be available in stock at the start of September and are available for preorder now, ONLY from OcUK in the UK. Expect to see a video and some reviews in the coming weeks!
Vertagear Racing Series S-Line SL2000 Gaming Chair Black/Carbon Edition @ £184.99 inc VAT
A combination of form and function, Vertagear’s SL-2000 series focus on ergonomics, design, and functionality. Designed to give wide range of adjustability that gives gamers the best comfort and support in every gaming position for extended period of time. High backrest is designed to provide neck, shoulder and lumbar support.
Adjustable seat height
To prevent repetitive stress, having the correct ergonomic posture is important when seated for a longer time. Seat adjustability makes sure every type of user from different heights can adjust the chair to their unstressed posture. Good range of height adjustability to ensure you are at the optimum angle in relation to your desk.
Adjustable armrest
Cushioned and contoured to the shape of the arm with adjustability in height gives support to the gaming arm and prevents repetitive stress.
Adjustable back
Features independent back angle option. An angle-adjustable backrest to help you adjust your sitting position throughout the course of your gaming experience (up to 170 degrees).
Elegant Exterior
The SL2000 is made of high quality PVC leather, which makes it extremely durable and gives the chair a luxurious look. This material is easy to clean and maintain due to it’s stain- and water-resistant characteristics.
Comfort Padding
The SL2000 padding is made of high densed foam, which adds great support and seat comfort to the chair. The open-cell breathing structure, makes sure that heat arised from the human body temperature won’t get trapped inside. This gives great comfort to the user even when seated for extended period of time.
Solid Structure
The SL2000 is constructed from a steel frame that assures a solid structure. The aluminum 5-star base keeps the chair solid, stable and lightweight. Assembled with a Class 4 gaslift, iindicates for better durability and ease of use. Our Class 4 Gas Lift has thicker walls to accommodate the higher pressure and stability.
Tilting feature with adjustable resistance and locking system
Our adjustable tilt tension mechanism allows you to increase or decrease the tension by easily turn the knob to match your body weight. This allows you to rock comfortably, without heavy pushing, reducing muscle fatigue.
Extra accessories
Additional neck support cushion and lumbar support cushion is included.
Soft-glide Wheels
Wheel is formulated for a quieter operation and greater resistance to foreign objects and debris.
Specifications
- Overall height (incl. base): 1280 - 1360 mm
- Width backrest (shoulder): 555 mm
- Width backrest (lumbar): 290 mm
- Width seat: 370 mm
- Depth seat: 540 mm
- Material(s): Steel (frame), High density resilient foam, PVC leather, Aluminum (feet)
- Max. Load: 150 kg
- Colour: Carbon Black
- Model: VG-SL2000
- Net Weight: 20 kg
- Gross Weight: 24 kg
- Package dimension: 880 x 400 x 680 mm
Only £184.99 inc VAT.
ORDER NOW
Vertagear Racing Series S-Line SL2000 Gaming Chair Black/White Edition @ £184.99 inc VAT
ORDER NOW
Vertagear Racing Series S-Line SL2000 Gaming Chair Black/Green Edition @ £184.99 inc VAT
ORDER NOW
Vertagear Racing Series S-Line SL2000 Gaming Chair Black/Blue Edition @ £184.99 inc VAT
ORDER NOW
Vertagear Racing Series S-Line SL2000 Gaming Chair Black/Red Edition @ £184.99 inc VAT
ORDER NOW
Vertagear Racing Series S-Line SL4000 Gaming Chair Black/Green Edition @ £214.99 inc VAT
Redefining gaming chairs, the SL-4000 brings unparalleled level of comfort and adjustability. Gamers spend hours each day in front of a computer, the new SL-4000’s high density padding and contoured backrest allows for an extremely comfortable gaming experience. Designed to give wide range of adjustability that gives gamers the best comfort and support in every gaming position for extended period of time. High backrest is designed to provide neck, shoulder and lumbar support.
Adjustable 4 point armrest
Cushioned and contoured to the shape of the arm with adjustability in 4 directions gives support to the gaming arm in every position and prevents repetitive stress.Ergonomically designed to provide support to the forearm, relieving muscle strain and fatigue from the shoulders and taking pressure of sensitive areas of the wrist.
Adjustable back
Elegant Exterior
The SL4000 is made of high quality PVC leather, which makes it extremely durable and gives the chair a luxurious look. This material is easy to clean and maintain due to it’s stain and water-resistant characteristics.
Premium Padding
The SL4000 padding is made of high densed resilient foam, which adds great support and seat comfort to the chair. The open-cell breathing structure, makes sure that heat arised from the human body temperature won’t get trapped inside. This gives great comfort to the user even when seated for extended period of time.
Solid Structure
The SL4000 is constructed from a steel frame that assures a solid structure. The aluminum 5-star base keeps the chair solid, stable and lightweight. Assembled with a Class 4 gaslift, for better durability and ease of use. Our Class 4 Gas Lift has thicker walls to accommodate the higher pressure and stability.
Extra accessories
Soft-glide Wheels
Specifications
- Overall height (incl. base): 1280 - 1400 mm
- Width backrest (shoulder): 520 mm
- Width backrest (lumbar): 300 mm
- Depth seat: 530 mm
- Max. Load: 150 kg
- Colour: Green
- Model: VG-SL4000
- Net Weight: 20 kg
Only £214.99 inc VAT.
ORDER NOW
Vertagear Racing Series S-Line SL4000 Gaming Chair Black/Red Edition @ £214.99 inc VAT
ORDER NOW
Vertagear Racing Series S-Line SL4000 Gaming Chair Black/Blue Edition @ £214.99 inc VAT
ORDER NOW
Vertagear Racing Series S-Line SL4000 Gaming Chair Black/Carbon Edition @ £214.99 inc VAT
ORDER NOW
Vertagear Racing Series S-Line SL4000 Gaming Chair Black/White Edition @ £214.99 inc VAT
ORDER NOW
Vertagear Racing Series S-Line SL5000 Gaming Chair Black/Carbon Edition @ £229.99 inc VAT
A gamer’s delight, the SL-5000 will hit the sweet spot for extreme gamers. Racing inspired design, the SL-5000 empowers the gamers’ everyday gaming with the right features. Instantly-recognizable style lets the world know how serious you are about gaming.
Adjustable back
Elegant Exterior
The SL5000 is made of high quality PVC leather, which makes it extremely durable and gives the chair a luxurious look. This material is easy to clean and maintain due to it’s stain and water-resistant characteristics.
Premium Padding
The SL5000 padding is made of high density resilient foam, which adds great support and seat comfort to the chair. The open-cell breathing structure, makes sure that heat arised from the human body temperature won’t get trapped inside. This gives great comfort to the user even when seated for extended period of time.
Solid Structure
The SL5000 is constructed from a steel frame that assures a solid structure. The aluminum 5-star base keeps the chair solid, stable and lightweight. Assembled with a Class 4 gaslift, for better durability and ease of use. Our Class 4 Gas Lift has thicker walls to accommodate the higher pressure and stability.
Extra accessories
Soft-glide Wheels
Specifications
- Overall heigth (incl. base): 1330 - 1450 mm
- Width backrest (shoulder): 510 mm
- Width backrest (lumbar): 305 mm
- Width seat: 380 mm
- Depth seat: 590 mm
- Max. Load: 150 kg
- Model: VG-SL5000
-Net Weight: 20 kg
-Gross Weight: 24 kg
-Package dimension: 880 x 400 x 680 mm
Only £229.99 inc VAT.
ORDER NOW
