I have no plans to upgrade for a few years so I've decided I want to watercool my current rig. Of note, I have a 4790k & 2x EVGA 980ti FTW inside a Phanteks Enthoo Evolv TG case. I've thrown together something but would like some advice from you more experienced guys! I know some of the fittings probably won't fit, and if you guys have some better suggestions for rads/fittings etc then I'm all ears. I'll be putting this together in about 2/3 weeks so would just like your input/suggestions before I pull the trigger. Thanks dudes!
My basket at Overclockers UK:
Total: £807.24
(includes shipping: £11.10)
- 1 x EK Water Blocks EK-Supremacy EVO - Nickel (Original CSQ)= £52.99
- 2 x EK Water Blocks EK-FC980 GTX Ti Strix Backplate - Black= £27.95
- 2 x EK Water Blocks EK-FC980 GTX Ti XG - Nickel= £89.99
- 2 x Three Fan Bundle - EK Water Blocks EK-Vardar F2-120 (1450rpm)= £36.96
- 2 x EK Water Blocks EK-CoolStream PE 360 (Triple)= £64.99
- 1 x EK Water Blocks EK-RES X3 250 Reservoir= £51.98
- 1 x EK Water Blocks EK-XTOP Revo D5 PWM - Plexi (incl. pump)= £86.99
- 2 x Mayhems Hardened Glass Watercooling Tubing Straight 16mm (OD) x 500mm= £7.99
- 10 x Bitspower Premium G1/4" Black Matte High Flow 3/8" (5/8") Compression Fitting= £6.98
- 1 x Koolance QD3 Female Quick Disconnect No-Spill Coupling, Male Threaded G 1/4 BSPP - Black= £11.95
- 1 x Bitspower Case Top Water Fill/ Through Hole Fitting Set - Matte Black Finish= £8.99
- 6 x Bitspower G1/4" Low-Profile Stop Fitting with O-ring - Black Matte Finish= £2.98
- 4 x Bitspower Adapter 90 degree 2x G1 / 4 inches - Matte Black= £9.95
Total: £807.24
