Hi Guys
I have spent the past few weeks working with Linus to assist in bringing his limited edition Noctua fans to market.
They will be available in Europe exclusively through Overclockers UK in GB and Caseking for the rest of the EU.
We all know that Noctua fans are pretty much the best there is without question. The only problem has been the lurid colour scheme they insisted on using. The main advantages of the Linus Tech Tips fans is the Full black colour scheme and the orange accents in the form of anti vibration pads. you can also remove these if you want a fully black stealth look.
The fans both come with LTT case badges and a center fan hub sticker [that isn't pre applied] as well as a Noctua LNA speed reducer which will make these already quiet fans, near silent.
Yes, they aren't cheap. We know that. Noctua fans, you get what you pay for and there really isn't anything better out there.
The Linus Tech Tips Announcment Video from Computex 2015:
Check out the Linus Tech Tips YouTube channel for informative and interesting enthusiast content.
Noctua NF-F12 PWM Linus Tech Tips Edition 120mm Cooling Fan @ £18.95 inc VAT
LinusTechTips is a hugely popular and influential YouTube channel where the very best PC Hardware is reviewed. This special edition fan is the first standard Noctua fan to feature unique colours more inkeeping with enthusiast builds.
The LinusTech Tips fans come in a stealthy black appearance which means you can get superior Noctua quality without having to pay for the industrial PPC fans just to get a subtle colour.
Teaming up eleven stator guide vanes with a specially conceived seven blade impeller, the NF-F12’s Focused Flow™ system creates outstanding static pressure and focuses the airflow for superior performance on heatsinks and radiators. At the same time, a wide range of advanced aerodynamic design measures, second generation SSO-Bearings and Noctua’s new, custom designed PWM IC for fully automatic control guarantee astounding quietness of operation. The NF-F12 comes with modular cabling, integrated anti-vibration pads and two speed settings for full flexibility. Its commanding performance, exhaustive set of features and Noctua’s trusted premium quality make it an elite choice for use on air coolers, radiators and other pressure demanding applications.
Specification:
- Format: 120 x 120 x 25 mm (W x H x D)
- Bearing Type: Bearing SSO2
- Blade geometry: Heptaperf
- Power consumption: max. 0.6 W
- Amperage: max. 0.05 A
- Operating voltage: 12 V
- MTBF:> 150,000 hours
- Connection: 4-pin PWM
- Manufacturer Warranty: 6 years
Accessories:
- 4-Pin Low-Noise Adaptor (LNA)
- 4-Pin Y-cable
- 4-Pin Extension Cable (30 cm)
- 4x Vibration inhibitors
- Square Aluminium LinusTechTips Case Badge
- Monochrome Center Fan Hub Sticker
- 4x Fan screws
Only £18.95 inc VAT.
ORDER NOW
Noctua NF-A14 PWM Linus Tech Tips Edition 140mm Cooling Fan @ £19.99 inc VAT
The NF-A14 is a premium quality quiet 140mm fan with a square frame that complies with Noctua’s AAO (Advanced Acoustic Optimisation) standard. Its square shape and 140mm mounting holes (124.5mm spacing) make it ideal for use on watercooling radiators or as an upgrade for 140mm case fans. Featuring sophisticated aerodynamic design measures such as Flow Acceleration Channels, the NF-A14 further improves the renowned quiet cooling performance of the award-winning NF-P14. The PWM version sports Noctua’s custom designed NE-FD1 IC for fully automatic speed control via 4-pin fan headers and comes with a Low-Noise-Adaptor to reduce the maximum speed during PWM control from 1500rpm to 1200rpm. Its performance-oriented 1500rpm top speed and comprehensive speed control options make the NF-A14 PWM an elite choice for users who strive to strike a perfect balance between excellent cooling capacity and superb quietness of operation, be it on watercooling radiators, on heatsinks or in case ventilation.
Specification.
- Dimensions: 140 x 140 x 25 mm (W x H x D)
- Material: Plastic
- Normal Mode: 1500 U / min, 24.6 dB (A), 140,2 m³ / h
- With LNA: 1200 U / min, 19.2 dB (A), 115,5 m³ / h
- Voltage: 12 V
- Power consumption: 1.56 W, 0.13 A
- Connection: 3-pin, 4-pin Molex adapter
- Life expectancy: 150,000 hours
Accessories:
- 4-Pin Y-cable
Only £19.99 inc VAT.
ORDER NOW
Specification:
Accessories:
- 4-Pin Y-cable
- 4x Fan screws
ORDER NOW
Specification.
- Material: Plastic
- Voltage: 12 V
Accessories:
- 4-Pin Y-cable
ORDER NOW
