** GIGABYTE XTREME GRAPHICS CARDS NOW AVAILABLE!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Gigabyte's new Xtreme range are not only faster, use better quality components and have features for extreme overclockers but also have really cool RGB LED's on the top of the cards and around the fans, allowing your to customise the look perfectly. :)
Gigabyte GeForce Titan X Xtreme Gaming 12288MB GDDR5 PCI-Express Graphics Card @ £899.99 inc VAT
The WindForce 3X cooling system features five 8mm and one 6mm composite copper heat-pipes, special fin architecture, unique blade fan design, and Gigabyte "triangle cool" technology, together delivering an effective heat dissipation capacity up to 700W for higher performance at lower temperatures.
The XTREME Gaming graphics cards are equipped with 3D-active fan, the industry's first 0Db semi-passive fan design introduced by Gigabyte back in 2007. The fans will remain off when the GPU is under a set loading or temperature for low power gaming. The LED fan indicator on the top of the graphics card provides an instant display of the fan status.
Multi-Colour illuminated LED with extra colour options and numerous lighting effects, you could now choose the right scheme for your gaming rig through OC Guru utility software.
Features:
- WINDFORCE 3X 700W cooling system
- Powered by NVIDIA GeForce GTX TITANX GPU
- Integrated with industry's best 12GB GDDR5 memory and 384-bit memory interface
- OC Edition - Core Clock: Base 1165MHz / Boost 1266MHz (Standard- Base:1000MHz Boost:1075MHz)
- Features Dual-link DVI-I / HDMI / DisplayPort*3
- System power supply requirement: 600W (with two 8-pin external power connector)
- Alternate Spinning Fan Design
- 3D active fan with LED indicators
- Unique blade fan design
- Multi-Colour illuminated LED
- GPU Gauntlet sorting
- Built for extreme overclockers with LN2 BIOS
- Stylish metal back plate
- LED Power indicators
- Aerospace-grade PCB coating for best protection
- 12+2 Power phase
- Titan X-grade chokes and capacitors used throughout entire Xtreme Gaming range of graphics cards
Specification:
- GeForce Titan X
- GPU: GeForce Titan X
- Core Base Clock: 1165MHz
- Core Boost Clock: 1226MHz
- Memory Clock: 7010MHz
- Memory Size: 12288MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 3072
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 3x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 700W PSU Required
- 250W TDP
- Warranty: 3yr
Only £899.99 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 980Ti Xtreme Gaming WaterForce 6144MB GDDR5 PCI-Express Graphics Card @ £659.99 inc VAT
Combining the high-end GTX 980 Ti GPU with Gigabyte all-in-one water cooling system to bring you the most exhilarating gaming experience and beyond.
The optimized pump and the full coverage copper base on the GPU/RAM/MOSFET deliver the most efficient water flow and cooling performance at a lower noise level.
Features:
- WATERFORCE All in One Closed Loop Water Cooling System
- Powered by NVIDIA GeForce GTX 980 Ti GPU
- Integrated with industry's best 6GB GDDR5 memory and 384-bit memory interface
- OC Edition - Core Clock: Base 1216MHz / Boost 1317MHz (Standard- Base:1000MHz Boost:1075MHz)
- 12+2 Power phase
Specification
- GeForce 980Ti
- GPU: GeForce 980Ti
- Core Base Clock: 1216MHz
- Core Boost Clock: 1317MHz
- Memory Clock: 7200MHz
- Memory Size: 6144MB GDDR5
- CUDA Cores: 2816
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 600W PSU Required
- 250W TDP
- Dimensions: L=282mm, W=110mm, H=43mm
- Warranty: 3yr
Only £659.99 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 980Ti Xtreme Gaming 6144MB GDDR5 PCI-Express Graphics Card @ £599.99 inc VAT
Features:
- 12+2 Power phase
Specification
- GeForce 980Ti
- CUDA Cores: 2816
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 600W PSU Required
- 250W TDP
- Warranty: 3yr
Only £599.99 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 970 Xtreme Gaming 4096MB GDDR5 PCI-Express Graphics Card @ £319.99 inc VAT
Features:
- Powered by NVIDIA GeForce GTX 970 GPU
- Integrated with industry's best 4GB GDDR5 memory and 256-bit memory interface
- OC Edition - Core Clock: Base 1190MHz / Boost 1342MHz (Standard- Base:1051MHz Boost:1178MHz)
- 10+2 Power phase
Specification
- GeForce 970
- GPU: GeForce 970
- Core Base Clock: 1190MHz
- Core Boost Clock: 1342MHz
- Memory Clock: 7100MHz
- Memory Size: 4096MB GDDR5
- Memory Bus: 256-bit
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 600W PSU Required
- 250W TDP
- Warranty: 3yr
Only £319.99 inc VAT.
ORDER NOW
Very very nice cards indeed! :)
D3K
D3K
13 Nov 2014
Damn late to the party with the hybrids. I hope all the manufacturers are on the ball with earlier hybrid pascal releases
9 Feb 2009
Looks like a standard 120mm AIO cooler slapped on the cards chip what about the vram ect whats cooling them???
26 Aug 2013
They do look nicer when all the fan RGB led rings are lit up.
Pity about the Waterforce. Does look rather rushed. Great that the Vram and Mosfet are also water-cooled, though.
22 Mar 2008
Waterforce may have looked better without the window. The logo doesn't look right, not been centred over the block.
Also the ridged tubes make it look cheap and a bit tacky.
