** YOU'RE GONNA NEED A BIGGER DESK: SAY HELLO TO OUR LARGEST MONITOR YET!! PHILIPS 43" 4K MONSTER!!
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
After the absolute huge success we have with the Philips 40" 4k (Over 1000 sold) we now have their latest 43" model which now features an IPS panel:
Philips BDM4350UC 43" 3840x2160 IPS 4K 60Hz Widescreen LED Monitor - Black @ £599.99 inc VAT
UltraClear 4K UHD Resolution
These latest Philips displays utilize high performance panels to deliver UltraClear, 4K UHD (3840 x 2160) resolution images. Whether you are demanding professional requiring extremely detailed images for CAD solutions, using 3D graphics applications or a financial wizard working on huge spreadsheets, Philips displays will make your images and graphics come alive.
IPS technology
IPS displays use an advanced technology which gives you extra wide viewing angles of 178/178 degree, making it possible to view the display from almost any angle. Unlike standard TN panels, IPS displays gives you remarkably crisp images with vivid colors, making it ideal not only for Photos, movies and web browsing, but also for professional applications which demand color accuracy and consistent brightness at all times.
MultiView technology for 4K
Philips MultiView feature on this expansive 4K UHD display enables you to have up to four systems each shown in Full HD on one screen. You can use the Picture-by-Picture (PbP) for monitoring four systems on one screen for control rooms or security. Or for multiple devices like two notebooks side-by-side simultaneously, making collaboration more productive. Or Picture-in-Picture mode (PiP) watching a live football feed from your set-top box, while working on your PC.
SmartUniformity
Fluctuations in brightness and color on LCD screens are a common phenomenon. Philips SmartUniformity mode delivers accurate images in terms of brightness; which is crucial for photography, design, and printing. With a color metric to assess color accuracy, this mode is calibrated to meet average luminance uniformity is greater than 95%. Selecting this mode will produce uniform and accurate images.
SmartImage
SmartImage is an exclusive leading edge Philips technology that analyzes the content displayed on your screen and gives you optimized display performance. This user friendly interface allows you to select various modes like Office, Photo, Movie, Game, Economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimizes the contrast, color saturation and sharpness of images and videos for ultimate display performance. The Economy mode option offers you major power savings. All in real time with the press of a single button!
7-Watt Speakers
A pair of high quality stereo speakers built into a display device. It can be visible front firing, or invisible down firing, top firing, rear firing, etc depending on model and design.
USB 3.0 Hub with FastCharge
Super Speed USB 3.0 deploys 5.0 gbit/s transfer rate, which is about 10 times faster than USB 2.0 standard significantly reducing data transfer time saving you time and money. With more bandwidth, super speed transfer rates, better power management and superior overall performance, USB 3.0 sets the latest global standard allowing you to use the large capacity storage devices. Now you don't have to wait so long for devices to charge. New FastCharge enables quick charging to charge and go. USB 3.0 is also backward compatible with USB 2.0 devices.
SmartConnect for 4K
These Philips displays come equipped with the most advanced multi connections like VGA, Display Port, universal HDMI connector, enabling you to enjoy high resolution uncompressed video and audio content. New DisplayPort and HDMI 2.0 connection now enables full 4K resolution at 60Hz for smooth visuals. USB connections ensures that you can have super speed data transfers while having global connectivity. Regardless of what source you use, you can rest assured that this Philips display will ensure your investment is not made obsolete any time soon!
Expand your viewing experience
- Expansive 43-inch class brilliant display
- UltraClear 4K UHD (3840x2160) resolution for precision
- IPS LED wide view technology for image and color accuracy
- MultiView 4K for 4 systems on one screen
- SmartUniformity for consistent images
- SmartImage presets for easy optimized image settings
Designed for the way you work
- Slim bezel design for a stylish look
- Powerful 7-Watt speakers to unleash your content
- USB 3.0 Hub for convenient access and fast charging
- SmartConnect with DisplayPort, HDMI and VGA connections
- MHL technology for enjoying mobile content on big screen
- VESA mount allows for the perfect setup
Specification:
- Size: 43"
- Display resolution: 3840 x 2160 pixels
- Colour of product: Black
- Aspect ratio: 16:9
- Contrast ratio (typical): 1200:1 (500,000,000:1 DCR)
- Display brightness: 300 cd/m2
- Response time: 5 ms
- Speakers: 2 x 7W
- HD-Ready: Yes
- HDMI ports: x2
- DisplayPort: x2
- VGA (D-Sub): x1
- Separate H/V sync: Yes
- Sync-on-green (SOG): Yes
- Headphone connectivity: Yes
- Operating relative humidity range 20% - 80%
- Maximum operating temperature range (T-T) 0 - 40
- Viewing angle: vertical 178 °
- Viewing angle: horizontal 178 °
- Number of colours: 16.7 million
- Power consumption: 63.1 W
- Dimensions With Stand: (W x H x D) 968 x 630 x 259 mm
- Dimensions W/O Stand: (W x H x D) 968 x 562 x 82 mm
- Weight: 9.72 Kg
- Weight W/O Stand: 9.40 Kg
- Warranty: 2yr
Only £599.99 inc VAT.
ORDER NOW
OcUK Staff
OP
17 Oct 2002
OcUK HQ
£600 for such a big screen seems like pretty good value to me?
It is actually very good value being IPS also. The outgoing 40" model was a big hit, be interesting to see if this follows in its place as that model is now end of life and stock is all but practically gone.
Caporegime
18 Oct 2002
Awesome monitor, but can't help but feel that Philips have missed a trick here. If it had Freesync then it'd sell double/triple figures!!!!
Shame, but still damn nice :cool:
OcUK Staff
OP
17 Oct 2002
OcUK HQ
I guess if we were to picky, it still lacking Freesync despite being a newer monitor replacing the old one.
I shall ask them if it is even remotely possible or if they plan a firmware update on another model supporting this. But Philips tend to not get involved in the gaming scene at all, they just happen to have some really nice high quality product that is fit for gaming as well as professional work. :)
