** VERY SPECIAL MEMORY ARRIVES AT OCUK! (WORLD FIRST)**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Arrived today we have Crucials flagship and most stunning (visually) memory to date, check the short video we've done here:-
Some key points about this memory:-
  • Orange & Blue OR Red & Green LED Kits available
  • Four different activity patterns
  • Ability to turn LED's ON/OFF & Choose just one or both LED's operation
  • Temperature Probes with Temperature Widget/Software available
  • CAS8 Timings
  • Extremely overclockable, managed 1866MHz C8 in our short testing
  • Crucial M-O-D FREE downloadable software/widget
The memory is in stock but won't be available to buy until 10am tomorrow, be sure to check our memory section and forums early tomorrow morning as stocks are limited and the pricing for such high performance memory with LED's is very good value.
This stuff is simply ACE! :D :D :D
OcUK Staff
OP
17 Oct 2002
OcUK HQ
OcUK Staff
OP
17 Oct 2002
OcUK HQ
awesome :D how much?
Hi there
The 4GB CAS8 kits shall be £36 each!
The 8GB CAS8 kits shall be £60 each!
However when I launch them tomorrow morning I may do a special promotion price as we purchased this RAM prior to the silly price increase which have happen this week, so expect some special introductory pricing tomorrow.
Shall be live for order from 10am tomorrow. :)
P.S. The MOD software you can download to use with these Ballistix kits is pretty awsome, very impressed with the built in temperature probes. :)
OcUK Staff
OP
17 Oct 2002
OcUK HQ
Hi there
Due to my dedication to the cause, I've stayed at work until this time and put them up for sale, you can now order them and get them delivered for Friday:-
Crucial Ballistix Tactical Tracer 8GB (2x4GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (BLTCP4G3D1608DT2TXRGCEU) (Red & Green Activity LEDs) **WORLD FIRST** @ £53.99 inc VAT
Crucial is all about the win—and our complete line of Crucial Ballistix performance memory is proof of that commitment. Whether you're a casual enthusiast or hardcore gamer, the expanded Ballistix line delivers a choice of performance memory that meets your need for speed.
Are you ready to shed some light on your computer?
Play with even more bling — customized by you. The Ballistix Smart Tracer features activity-indicating LEDs on the top edge and ground-effect LEDs along the bottom.
These Smart Tracer modules are available in either Blue/Orange or Red/Green LED color combinations that you can manipulate in real time, switching up the color options. In addition, select from four different LED patterns, adjust brightness, or turn the LEDs on/off. All of this can be done on-the-fly! Turn on the lights — and turn up your performance — with Ballistix Smart Tracer memory.
Add to it the downloadable MOD utility, and you get the real-time temperature monitoring — and more!
Features:-
- Black PCB
- Black high performance CAMO ALU heatspreaders
- Ultimate performance memory
- Activity LED's
- Temperature Probe
- Crucial MOD software compatible
- Each two module set is tested at 1600MHz
- Tactical heat spreader for performance
- Packaged together immediately following system test
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 8-8-8-24 on Intel DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 8-8-8-24 values at 1600MHz, 1.50V
- 8192 Megabytes of DDR3 memory
- Two matched 4GB modules
- 100% tested at 1600MHz in Intel based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
- Sandybridge compatible
- Bulldozer compatible
Was [£59.99] Inc. VAT
Only £53.99 inc VAT.
ORDER NOW
Crucial Ballistix Tactical Tracer 8GB (2x4GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (BLTCP4G3D1608DT2TXOBCEU) (Orange & Blue Activity LEDs) **WORLD FIRST** @ £53.99 inc VAT
Features:-
- Black PCB
- Activity LED's
- Temperature Probe
- Lifetime Warranty
ORDER NOW
Crucial Ballistix Tactical Tracer 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (BLTCP2G3D1608DT2TXRGCEU) (Red & Green Activity LEDs) **WORLD FIRST** @ £29.99 inc VAT
Features:-
- Black PCB
- Activity LED's
- Temperature Probe
- 4096 Megabytes of DDR3 memory
- Two matched 2GB modules
- Lifetime Warranty
Was [£35.99] Inc. VAT
Only £29.99 inc VAT.
ORDER NOW
Crucial Ballistix Tactical Tracer 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (BLTCP2G3D1608DT2TXOBCEU) (Orange & Blue Activity LEDs) **WORLD FIRST** @ £29.99 inc VAT
Features:-
- Black PCB
- Activity LED's
- Temperature Probe
- Lifetime Warranty
ORDER NOW
17 Dec 2006
I was going to buy the Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) [KHX1600C9D3X2K2/8GX] for my new build would these be a lot better, visually i know, but what about performance?
