Tried out Route 66's Navigate 6, which launched a few days ago. You download the app for free and then can get free worldwide Navigation, traffic and speed cameras via the in app store for 30 days. Maps and HD Traffic both from TomTom.
I tried it both ways on my commute today and came away impressed. I ran it at the same time as TomTom and although the traffic info is the same, Navigate 6 appears to have a more aggressive avoidance algorithm. TomTom has a 4 minute delay threshold for redirection and this seems to be less. It diverted me around two jams that TomTom would have needed manual intervention to avoid. The very similar ETAs generated make me suspect that it's using Tom-Tom's IQ Routes, or least has their Speed Profiles integrated into the maps.
The mapping and search interface is a big improvement over TomTom. Addresses and points of interest can be found in seconds.
It uses Android's native text to speech and while this isn't as natural sounding as Tom-Tom's TTS, the instructions themselves are clearer.
Definitely worth a try if you want to try out a new Satnav app.
Edit: after a few days using the app - it appears that the routing and traffic avoidance in Navigate 6 seems pretty much functionally identical with http://routes.tomtom.com, at least for short distances. You can use Tomtom's online route planner to preview the routing behaviour in this app, which is slightly different to the Tomtom app itself.
