32GB DDR4 - overkill now but what about in 5 years time?
3 Jul 2008
London
I'm putting together a build for a new PC, either Z170 or x99 (still deciding). Either way it will be DDR4.
I'm considering buying 32GB of DDR4 (4 x 8GB) rather than 16GB because prices seem in a good place at the moment.
I know this is overkill for current applications and games, but I want any new build to last about 5 years without needing to upgrade.
I use my PC for productivity (Photoshop, Painter, Illustrator), gaming (mostly MMOs, RPGs like Witcher 3, DA:I, Mass Effect etc and space games like Elite Dangerous and Star Citizen). Plus media consumption (Prime etc).
I know no-one has a crystal ball, but anyone care to speculate on where prices and requirements might go over the next 5 years? How long will DDR4 be with us (as older RAM becomes harder to find later and more expensive)?
2 May 2004
Really depends what you do. If you just run one game at a time, close it, then do other stuff then 8GB would probably be OK. I would really struggle with 8GB at home and just about hit 16GB regularly at work (Photoshop, Visual Studio, VMs, etc.).
All these things are also still optimised for your average user, so unless you run them all at once, you're not going to need that much RAM.
OP
3 Jul 2008
London
I tend to multitask a lot. I'll often have Photoshop, Painter and Illustrator all open at the same time. Or I might be running a game on one monitor and TV on the other (if its a game that's not taking my full attention). I'm rarely just doing one thing on the PC.
My current system has 8GB, built at a time when 4GB was considered a lot. But I've never felt it was too much ram.
I guess I'm answering my own question aren't I ... 32GB probably isn't overkill for my uses, at least not in the long run.
11 Mar 2013
Go for it mate. DDR4 is very cheap ATM so 32gb would be just perfect for your needs.
19 Jun 2009
If you shoot in RAW then you can can easily use past 16GB with multiple files open.
Always buy memory when it's cheap, also no worries trying to match memory later on, plus dust / dirt can't get into spare memory sockets, potentially causing issues when you upgrade in future. If you fill all your slots up now the memory sockets are protected.
I have 32GB of Kingston 1600 DDR3 I purchased new for £80 in 2012, back then 32GB would have appeared a crazy amount but it was a good investment.
Intel CPU's have very good cache systems, making new memory technology / speed less important. In 5 years I expect my 32GB of 1600 DDR3 will still be in use, let alone DDR4.
Just add one more thing. Apparently Kingston has less returns on memory at OCUK, especially as your planning on keeping memory long term, go for quality over speed and don't overclock, the memory should remain trouble free for it's life.
27 Jan 2016
In 5 years? I absolutely see 32gb as a good thing.
Ram is a good price right now, so I say go for it!
But I'm in the DDR4 bandwagon.
Go with: G.Skill Ripjaws V Series 4x8gb. 176 quid.
4 Sep 2013
you need 8gb right now to game so..... anything more is better.
i cant see needs passing 16gb in the next few years
4 GB is fine for gaming. Using the verb 'need' is very misleading. Maybe 'want' would have been better.
@OP I have 16 GB, I don't run as many heavy programs as you but my system tends to have a good 4GB in use and 6-8 GB in reserve allocation. If I want to run a game that's another 2-3 GB. Personally I prefer to have as much RAM as I can afford after I've hit my goals on the CPU/GPU. I also run opensource OS's though which appreciate a lot of ram (caching all those libraries ftw)
Permabanned
6 Feb 2010
Barnsley
4gb is not ok for gaming. you can run a game with 2gb but the game performance will be less reduced. right now you need 8gb of ram for programs like game to run at full speed in reference to memory.
with a lot of new games you get reduced performance with 8gb as there needing 16gb, but they do still work
6 Feb 2004
England
I upgraded to 8GB in 2008. It might have been a bit premature but to suggest 4GB is enough in 2016 is laughable. Games will probably run because windows handles all the memory management but obviously things will be paged out to disk when you run out and this is significantly slower.
21 Feb 2010
UK
i have 16gb now on a x99 build and im going to upgrade to 32,
my reason is i use so many tabs in chrome and image software so its worth just doing it esp with todays prices
22 Jul 2012
UK
Quite a few games are now flagging 8Gb as minimum spec. I would call that an absolute minimum for a gaming PC now. :D
Though 8Gb is probably fine now, things are evolving to 16Gb (and then I assume 32Gb in about 5 years).
But the OP mentioned DDR4 as well, and that's a whole different issue?
Caporegime
18 Oct 2002
London
It seemed to take ages for people actually needing to pass 4GB for general purposes and gaming, yet 8GB and more seems to have come around quite quickly.
