** NVIDIA GTX 1080 FOUNDERS EDITION: WANNA PRE-ORDER?
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
So now all our GTX 1080 Founders Edition cards are live, you will be able to pre-order next Friday at 14:00, we are also expecting several lines in stock by then but volumes are low to begin with so do be quick!
REGISTER TO GET FREE NEXT DAY SHIPPING VOUCHER CODE FOR GTX 1080!
Zotac GeForce GTX 1080 "Founders Edition" 8192MB GDDR5X PCI-Express Graphics Card (ZT-P10800A-10P) @ £635.99 inc VAT
NVIDIA’s flagship GeForce® GTX 1080 is the most advanced gaming GPU ever created, powered by the high-performance, energy-efficient new NVIDIA Pascal™ architecture. Pascal enables truly game-changing performance with captivating sights and sounds, as well as next-generation VR performance that offers the lowest latency and plug-and-play compatibility with leading headsets.
NVIDIA Ansel Technology exclusive to 10 series allows you to grab a screenshot in supporting games such as The Divsion and upcoming Unreal Tournament from any 360 degree position, ability to increase resolution, use cool filters so that you can screenshot those perfect headshots and view them in a full 360 degrees.
NVIDIA VR AUDIO Works Technology exclusive to 10 series is interative audio so realistic path traced audio meaning sound bounces off objects just like it would in the real world further improving the gaming experience on the audio side.
NVIDIA GeForce 10 series is based on 16nm finfet architecture resulting in just 180W TDP power consumption for a graphics card that can outperform Titan X in many situations whilst being upto three times more efficient. Overclocking headroom is also exceptional with around 2GHz core overclocks being possible (not guaranteed) resulting in 20% and higher overclock potential.
NVIDIA Simultaneous Multi-Projection Technology renders multi screens in one path mean performance in Virtual Reality titles on VR headsets such as HTC Vive and Oculos results in double the performance of Titan X making 10 series the King of Virtual Reality and whilst being upto three times more efficient at the same time.
Specification:
- GPU: GeForce® GTX 1080
- CUDA cores: 2560
- Video Memory: 8GB GDDR5X
- Memory Bus: 256-bit
- Engine Clock Base: 1607 MHz
- Boost:1733 MHz
- Memory Clock: 10,000 MHz
- PCI Express 3.0
- Display Outputs: 3 x DisplayPort 1.4, 1x HDMI 2.0b, 1x DL-DVI
- HDCP Support: Yes
- Multi Display Capability Quad Display
- Recommended Power Supply 500W
- Power Consumption 180W
- Power Input 8-pin
- DirectX 12 API feature level 12_1
- OpenGL 4.5
- Cooling Blower
- Slot Size Dual Slot
- SLI Yes
- Supported OS Windows 10 / 8 / 7 / Vista
- Card Length 266.7mm x 111.15mm
- Warranty: 5yr
Only £635.99 inc VAT.
EVGA GeForce GTX 1080 "Founders Edition" 8192MB GDDR5X PCI-Express Graphics Card (08G-P4-6180) @ £635.99 inc VAT
NVIDIA’s flagship GeForce® GTX 1080 is the most advanced gaming GPU ever created, powered by the new NVIDIA Pascal™ architecture. The GeForce® GTX 1080 comes with ultra-fast FinFET and high-bandwidth GDDR5X technologies, plus support for DirectX 12 features to deliver the fastest, smoothest, most power-efficient gaming experiences. Get the power to drive VR, ultra-high-resolution, and multiple monitors. Plus, bring more realism to every game with NVIDIA GameWorks™ technologies that deliver a true cinematic experience, smoother gameplay, and amazing new image-capture to share your game. All with the lowest latency and plug-and-play compatibility with leading VR headsets.
Specification:
- CUDA cores: 2560
- Boost:1733 MHz
- PCI Express 3.0
- HDCP Support: Yes
- Power Input 8-pin
- OpenGL 4.5
- Cooling Blower
- SLI Yes
- Warranty: 3yr
Asus GeForce GTX 1080 "Founders Edition" 8192MB GDDR5X PCI-Express Graphics Card @ £649.99 inc VAT
Specification:
- CUDA cores: 2560
- Boost:1733 MHz
- PCI Express 3.0
- HDCP Support: Yes
- Power Input 8-pin
- OpenGL 4.5
- Cooling Blower
- SLI Yes
- Warranty: 3yr
Only £649.99 inc VAT.
Gigabyte GeForce GTX 1080 "Founders Edition" 8192MB GDDR5X PCI-Express Graphics Card (GV-N1080D5X-8GD-B) @ £635.99 inc VAT
GAMING PERFECTED
NVIDIA’s new flagship GeForce GTX 1080 is the most advanced gaming GPU ever created. Powered by the new NVIDIA Pascal™ architecture, the GeForce GTX 1080 delivers up to three times the performance of previous-generation graphics cards, plus superior energy-efficiency, innovative new gaming technologies, and breakthrough VR experiences.
PERFORMANCE
The GeForce GTX 1080 comes with ultra-fast FinFET and high-bandwidth GDDR5X (G5X) technologies, as well as support for DirectX 12 features to deliver the fastest, smoothest, most power-efficient gaming experiences.
THE LATEST GAMING TECHNOLOGIES
GeForce GTX 1080 is built to meet the demands of next-generation displays, including VR, ultra-high-resolution, and multiple monitors. It features NVIDIA GameWorks™ technologies for extremely smooth gameplay and cinematic experiences, plus revolutionary new 360-degree image capture—even in VR.
VR READY
Discover next-generation VR performance, the lowest latency, and plug-and-play compatibility with leading headsets—driven by NVIDIA VRWorks™ technologies. VR audio, physics, and haptics let you hear and feel every moment.
GROUNDBREAKING NEW DESIGN
The new GeForce GTX 1080 is meticulously crafted to offer superior heat dissipation using an advanced vapor chamber and premium materials, so it runs as cool as it looks.
Specification:
- CUDA cores: 2560
- Boost:1733 MHz
- PCI Express 3.0
- HDCP Support: Yes
- Power Input 8-pin
- OpenGL 4.5
- Cooling Blower
- SLI Yes
- Warranty: 3yr
Palit GeForce GTX 1080 "Founders Edition" 8192MB GDDR5X PCI-Express Graphics Card @ £619.99 inc VAT
Specification:
- CUDA cores: 2560
- Boost:1733 MHz
- PCI Express 3.0
- HDCP Support: Yes
- Power Input 8-pin
- OpenGL 4.5
- Cooling Blower
- SLI Yes
- Warranty: 2yr
Only £619.99 inc VAT.
OcUK GeForce GTX 1080 "Founders Edition" 8192MB GDDR5X PCI-Express Graphics Card @ £619.99 inc VAT
Specification:
- CUDA cores: 2560
- Boost:1733 MHz
- PCI Express 3.0
- HDCP Support: Yes
- Power Input 8-pin
- OpenGL 4.5
- Cooling Blower
- SLI Yes
- Warranty: 2yr
KFA2 GeForce GTX 1080 "Founders Edition" 8192MB GDDR5X PCI-Express Graphics Card @ £619.99 inc VAT
Specification:
- CUDA cores: 2560
- Boost:1733 MHz
- PCI Express 3.0
- HDCP Support: Yes
- Power Input 8-pin
- OpenGL 4.5
- Cooling Blower
- SLI Yes
- Warranty: 2yr
Gainward GeForce GTX 1080 "Founders Edition" 8192MB GDDR5X PCI-Express Graphics Card @ £619.99 inc VAT
Specification:
- CUDA cores: 2560
- Boost:1733 MHz
- PCI Express 3.0
- HDCP Support: Yes
- Power Input 8-pin
- OpenGL 4.5
- Cooling Blower
- SLI Yes
- Warranty: 2yr
Inno3D GeForce GTX 1080 "Founders Edition" 8192MB GDDR5X PCI-Express Graphics Card (N1080-1DDN-P6DN) @ £619.99 inc VAT
GAMING PERFECTED
PERFORMANCE
VR READY
Specification:
- CUDA cores: 2560
- Boost:1733 MHz
- PCI Express 3.0
- HDCP Support: Yes
- Power Input 8-pin
- OpenGL 4.5
- Cooling Blower
- SLI Yes
- Warranty: 3yr
MSI GeForce GTX 1080 "Founders Edition" 8192MB GDDR5X PCI-Express Graphics Card @ £635.99 inc VAT
Specification:
- CUDA cores: 2560
- Boost:1733 MHz
- PCI Express 3.0
- HDCP Support: Yes
- Power Input 8-pin
- OpenGL 4.5
- Cooling Blower
- SLI Yes
- Warranty: 3yr
SEE ALL GTX 1080'S - CLICK HERE!!
17 Feb 2015
Joke price. Not your fault Overclockers as i realise this will be nationwide, but still.
Not funny.
Founders edition $699 = Reality $950.
Pull your trousers down and sing for England . . .
21 May 2008
Lincs
LOL prices to be honest!
A real shame the prices are marked this high as a lower price point would have cleared up. Regardless Im sure a lot of people will pay.
GJ Nvidia et al.
29 Mar 2003
Hull
Ill wait, the 970 will last for a time yet. Maybe the 1070 will be sensible, at these prices even the non founders editions will be over £550, I hate to think what the TI will end up being.
