8Pack Xtreme Skylake 6700K at 4.8ghz+ BWE at 4.4+ Overclocked upgrade bundles.
OcUK Staff
20 Feb 2012
John Smiths Stadium
I am pleased to bring to OCUK customers a new range of 8Pack Z170 and X99 Xtreme pre- overclocked bundles for the customer to hit xtreme performance out of the box.
These bundles are hand tuned by myself and use only the highest bin of CPU in conjunction with class leading components to achieve very high stable overclocks. This hike in performance will assist in removing the CPU bottleneck in any gaming or professional rig.
The Z170 bundles come in all three form form factors with a 6700K Skylake CPU overclocked to at least 4.8ghz 100% stable. Gaming and other none AVX tasks this bin of CPU is often stable at 4.9 or even 5ghz such is the standard of the silicon. Each CPU also has a strong IMC and has been pre-tested at such clocks with 3733mhz mems.
Each bundle has various memory options from 16gb-32gb DDR4 capacity. Motherboard options also exist so the customer can achieve the system look they want. The bundles also have various cooling options to accommodate a large range of cases. Just use the drop down menus to select!!
Buy one of these Z170 8Pack Xtreme bundles here:
ITX
https://www.overclockers.co.uk/8pac...hz-configurable-skylake-bundle-bu-004-8p.html
MATX
https://www.overclockers.co.uk/8pac...ble-overclocked-skylake-bundle-bu-003-8p.html
ATX
https://www.overclockers.co.uk/8pac...ble-overclocked-skylake-bundle-bu-002-8p.html
For the X99 power user I also have Xtreme Broadwell-E bundles again using the finest bin of CPU that overclock to a 100% stable 4.4ghz but can often go higher for Gaming or benching to 4.5ghz - 4.6ghz.
Just like Z170 these bundles have various cooling options and are overclocked on an individual basis by myself. The X99 Xtreme Broadwell-E customer can select between an 8 Core 6900K or a 10 Core 6950X CPU, can choose ASUS Rampage 10 or MSI Titanium Motherboards and memory configurations upto 64gb quad channel.
Buy your X99 8Pack Xtreme Bundle here:
https://www.overclockers.co.uk/8pac...locked-entusiast-gaming-bundle-bu-001-8p.html
++++++NO COOLER OPTION NOW AVAILABLE ON EACH OF THESE BUNDLES FOR THOSE WITH A MINIMUM OF 240 AIO for Z170 and CUSTOM 240 for X99.===========
9 Oct 2013
Next time I buid a new PC I'm probably going to go with one of these bundles, probably not the X99 though. Great bundles and prices
OcUK Staff
OP
20 Feb 2012
John Smiths Stadium
Call to order we can remove it at tele-sales level.
Customers who do remove must have a minimum of Dual AIO for Skylake and Triple AIO / Dual Custom for BWE.
21 Feb 2006
8 Pack is there any option to buy a binned 6700K separately or do you only bin chips for these sorts of bundles?
Also just curious about what volts you normally push 6700Ks for customer bundles? :)
15 May 2012
Louth, lincs
Great bundles but a shame there so late, they will still sell but not in the numbers they could have.
Being caseking owned can you not do the same as Roman, offer binned cpu's with warranty?? Or actually just binned cpu's that go well cold, not really into paying £1k+ for an 8 threader so no warranty would keep cost down a bit??
