Broken car, opinions?
M0T
M0T
23 Aug 2003
House
Well, 2 weeks into my Alfa ownership it has all gone slightly pearshaped.
Noticed a knocking noise from the engine bay and spent quite some time trying to locate it, as it was very quiet (thought it was the aux belt tensioner). As I was working my way around the engine bay it suddenly became a loud knocking coupled with the sound of a small midget shaking a large bag of nails around.
One oil drain later and I have determined that there has been a failure of the big end bearings. Unfortunatly these engines are not particularly sturdy and when the bearings let go the cranks need regrinding which is an engine out job and quite expensive.
A used engine costs less than the repair costs of the current one.
I have scouted around and found a 2.5l V6 engine with 56k on the clock for £646. On top of this I need to add £200 for a cambelt kit, £50 for the tools to change the belt, £50 for a water pump, £30 for an upper wishbone, £10 for an engine mount + oil and coolant costs. This puts the total cost of repair at almost £1000.
Now my dad is paying for all this, and he mentioned that in his opinion it would probably best to write off the £800 already spent on it and just buy another one, which would run to a further £2000+.
What should I do, fix this one or buy another one?
Best option is to break it for spares, if the head's not damaged then you'd be able to flog that for a fair amount i'd imagine.
Break it for spares, get as much back as you can, then dont buy another italian car. Italian cars are rubbish, youve now seen this first hand.
Before anyone takes offence, i have known lots of people with italian cars from fiat's to ferrari's, all have broken down stupidly, and generally been more trouble than they are worth.
Comming from a Merc owner that's a bit rich! Those germanic barges are not only unreliable, but are soulless euroboxes.
On the other hand my dads fiat has been no trouble and nor has his friends alfa.
We are waiting on a price for a 56k engine with all belts + tensioners changed before deciding what to do.
agw_01 said:
You still got the Rover?
It was taken away by a scrappy. I got the better deal because the engine failed spectacularly when he went to move it and it was rusted severely, lots of structural problems.
I can see why you thought that an Alfa would be a step up from Rover:D
I'd sell it off for spares and start again, it really is pot luck on Italian cars
Unreliable? Most of the people i know drive mercedes and BMW, none of whom have had major issues as the ferrari and alfa owners have. The only semi reliable italian marque seems to be fiat as far as i can work out. Everyone ive known with a ferrari and or alfa romeo's has had huge expensive issues, constantly throughout ownership. You might get a good one, but chances are you wont. This is reflected in the age old alfa jokes, and their terrible residuals.
Soulless euroboxes is something i would attribute to things like astra's and focus' and golf', not high end BMW's and Merc's.
My dad's 1.8TS had this happen. He caught it while it was still a wee tap, but still needed an exchange crank.
Sometime you get lucky and the crank survives in tact, it's made of really tough nitrided steel stuff.
Cross yer fingers when you take the big ends apart.
