people actually have alarms by their bedside? i thougt that was just in movies.
when my alarms go off, i get up, go to the desk (opposite side of room) turn off, walk to cupboard (back near bed) reach to top of cupboard (near ceiling) turn off.
then i go back to sleep.
once i forced myself to go to shower instead of going back to sleep.
i fell asleep in the shower, fell down, hitting my head on the (presumably) tap and lay there. when i woke up, my head was bleeding and i was about 2cm away from drowning because i had blocked the plughole when i fell down.
not doing that again.
I've tried putting 2 very loud alarms positioned around my bedroom but I've some how obtained the ability to turn them off whilst still sleeping.
I think I will make a little program which plays music at a set time and the only way to turn it off is to answer a range of very simple questions. I should hopefully wake up properly because I will actually have to use a bit of brain power![]()
i've been thinking about making an alarm clock with a 10 digit keypad on top, and when the alarm goes off, the display flashes a randomly generated 4 digit code, which must be entered in to turn the alarm off.
Not a bad idea of course they might just pull the power cord out or whatever
You would need to unscrew some kind of plate to access the batteries. Only way to kill it is to throw it out the window
I then decided to set me alarm about 1/2 before I wanted to be up with the Rocky theme music to inspire me to jump out, down some raw eggs and run up some steps. However this has only resulted in an extra 1/2 hour of snooze button hitting!
