Very usefull Air filter Review
Thats why I got this one. :)
How the heck does ANYONE think a non-oiled stainless steel mess of the first one in that test actually FILTER anything??!
A lot of the time it also depends on the intake tract from filter to engine, something that gives a straighter path for the air should be better :) Bends are bad mmkay.
so which one of these filters introduces a bend into the tract exactly?
None, my response was geared to the argument that these power results could only be valid for the one car they were tested on. i.e. the restriction on another car might not be the filter at all, it could be to do with the tract after the filter. I'm also not talking about the filtration properties of each, just the power increase.
If all the filters were giving around the same increase then I'd guess that something else along the way is causing another restriction, replacing the stock filter setup is just the first step :)
Based on the filtration results though you'd have the Apexi everytime surely??
