Hi Guys , just got 2 x 2x1Gb PC 8500 Ballistics kits BL12864AA1065 from an online retailer (not from Overclocker). The antistatic bags were already cut which leads me to believe that these are used in someway. Looking carefully at the contact pins, you can see that they have been inserted into a MB before, not sure if all sticks get tested individually before shipping from Crucial).The lables all seem to be authentic, and mubers match that printed on the antistatic bag, though on one kit there appears to be some label residue (arrowed) on one side of the spreader. The number on the PCB of each stick in 1 matched kit is different (73601 & 73702). The second kit Has the same 2 different numbers printed on them. Can someone check their matched pairs and see if theye have differing numbers. Also is there anyway on confirming that these are indeed PC8500 ram not some clever label swap? I haven't put in in my MB yet (have to pick the new one up from the depot in the morning).
Just want to figure out if its worth rejecting the RAM even if it works fine, to avoid the hazzel and want to start rebuilding the rig this WE. I know I have a lifetime warrantee as a back up.
Cheers
Cheers
