As titled I fancy a quad core but wondering if it's worth waiting till March for the Q9450? Or am I better off getting a 2nd hand Q6600 off MM? Any indication of UK prices for these bad boys?
They will come in at just under 300 I reckon.
I thought they were supposed to be replacing the Q6600s? Granted the demand will probably push the price up to £220 or so...
What's the max multi on the 9450? 8x? Unless you can get a really good FSB, the Q6600 (G0) is still prolly a better bet for 4GHz (if you're going that far). Not many mobos will do that.
If you had owned your Q6600 for a good few months then I suspect the premium for a new *toy* would probably be worth it.but will it be worth the extra 70quid
If it's any more than a £45 price gap between the Q9300 and Q9450 I swear I'll post hi-def pictures of me spraying cillit bang in my undies.
Q6600 (2.4Ghz, 8MB total L2) - £160 ($266)They will come in at just under 300 I reckon.
I would argue that for gaming a quad isn't worth upgrading to from a duo @3.2 ghz yet.
If the Q9450 isn't that much better I'll just go with the Q6600.
