I already have a quad running prime stable at 3.8ghz 24/7 and it benchies at 4.1ghz.
I think the 8400 and 8500's are pricey for what they are.
At above 3.6ghz Games will show no benefit as it then becomes the the GPU thats the bottleneck.
YOU WILL NOT NOTICE ANY IMPROVEMENT IN GAMES RUNNING EITHER 3.6GHZ QUAD OR 4.5 GHZ DUAL.
Period.
4ghz quad is no longer interesting and 4.5ghz dual is dull too.
If I was getting a E8xxx cpu it would have to be the 8500 to try and break the 5ghz barrier stable.
Doesn't the G0 Quad use less vCore or run cooler than your B3?Well see I had a B3 quad @ 3.6ghz before this and this G0 quad clocks pretty much the same.![]()
At the end of the day new games will support quad core and from those results the gains are massive with quad core supported games.
The quad even beats a 200MHZ faster dual core in everything aprt from company of heros.
Even then its by a tiny amount even though the dual is running 200 Mhz faster.
, seems odd but if this is indeed true I'm going to go the quad route I think proberbly.P5B Deluxe and GeIL PC6400 Ultra
From the other thread:
Well I just seen those benchmarks and I never realised even 1 core on a Q6600 is faster than one core on an E6850 even though on the quad its 200Mhz slower, seems odd but if this is indeed true I'm going to go the quad route I think proberbly.
I shall be buying a E8500 purely to see if I can get it stable @ 5ghz+![]()
Maybe I should just keep my E6600 surely it will hold and be strong up untill september? I'm going to college/uni in september or october and I'll be moving across the country so will proberbly build a brand new PC or update it before I go, so maybe E6600, 4GB DDR2 ram, P35C DS3R and ATi 3870X2 should play most or everything high at 1680x1050 up untill september?
