- 4 Feb 2008
- Northern Ireland
There you go.
Nice looking case with lots of room I see. How good is airflow?
and may i be the first to say tidy your room up!!!!!!!!![]()
I wish they'd sell that thing without the dual PSU's.
It walks all over the P182 imo; amazing ventilation, more space for extendo PSU's & GPU's and retains the compartmentalised design.
What's the price without PSU?
This case's one downside is that it doesn't come without the PSUs. I spent ages arguing with myself, deciding whether to get this or the Lian Li PC-P80. But in the end, it was totally worth it.
Just two questions if you mind .... is that a quick removable filter on the 200mm side fan and whats the damage on postage (ie cost) ..Thanks for the pics ..very nice... Im thinking about getting one myself and lucky for me I need a power supply upgrade anywaysJust two questions if you mind .... is that a quick removable filter on the 200mm side fan and whats the damage on postage (ie cost) ..
Cheers m8
Whats the main difference between the P180 then?
Neo-Link 1200 Watt dual power supply system: One 650 Watt Neo Power is
responsible for powering the motherboard and add-in cards, while another 550 Watt, handles your drives and other peripherals
Well it would take 1 min to get it out. Pop off the side, and then remove.
A bit of a pain, but I guess its the price we pay.
£16.95 postage to Northern Ireland. Might be a little cheaper on the mainland.
