From my understanding, the 160gb is 1 platter of 160gb, the 500gb is 3 x 166gb platters, and hence the 500gb has higher density platters it should be faster...but only 6gb shouldnt really make much of a difference...thats just my understanding so i may be wrong and it might not be the reason![]()
Yes and the AAJS is the single platter version of the AAKS so the speeds should be the same since they use the same platter as far as I'm aware.They're different drives. Ones single platter the other isn't. One's the AAJS series, the other is the AAKS series.
Yes it does so disks with 1, 2 or 3 identical platters should have the same maximum, minimum and average transfer rates. All that differs is that the fastest (and consequently slowest) x% of the disk is 3 times larger on the 3 platter drive than the single platter one.Doesn't a disk with multiple platters read down through the platters?
