Firefox 3.0 Download Day (Guinness World Record)
Autoscroll and using the mouse wheel to scroll through the tab list are there by default, unless you have some extension breaking them.
I've tried disabling all my extensions and restarting, still no autoscroll/mouse tab scroll :/
Edit: Found autoscroll in the options, it was disabled (Didn't know it was called that, though). Still no luck on the tabs.
Also, alt+s isn't working properly. It just selects the 'submit reply' box without actually clicking it.
uTorrent works here too. Version 1.7.7 with release Fx3. :confused:
That the WebUI?
The only version of the webui I could ever get hold of was an old one, mostly because I run uTorrent 1.6 as the version is prior to them being bought out by the big company that bought them out that spies on you. :p
Even though it's old code I'm confused/surprised that it won't load it as it shouldn't make a difference really.
InvG
Secondly, if I hit the scroll wheel in the middle of the page, it doesn't do that thing where you can just move the mouse down or up and it smoothly scrolls the page as well. I doubt the missing extension (All in one mouse gestures) would have done both of these, would it?
AIOMG does do the tab scrolling thing.
Nearly 1.3 million downloads - nice :D
Drat it all. Not compatable in FF3, and can't get onto the addons site to scout out a replacement. Is there a way to force it to try and work anyway? I think someone mentioned you could in the thread, but I don't remember seeing how.
And in FF2 they did change it so you needed a fancy key combo for alt+s, but in that case it brought up the bookmarks toolbar instead.
I can use my scrollwheel to move through the tab bar in a brand new profile :confused:
I'd suggest trying a new profile over anything else.
tolien said:
extensions.checkCompatibility.
That the WebUI?
Yeah. I'm guessing they've changed something between what you've got and the latest one then.
There's been a load of tweaks to JS on Fx3, it's possible uTorrent changed their code because of that.
The Field Guide to Firefox 3 is a decent read.
