Anyone good at maths???
7 Feb 2004
I work at a call centre and we have to answer a 80% of calls within 20secs.
can someone come up with a formula for predicting number of calls which could be taken without failing this.
So if we have taken 628 calls and have answered 87% how many calls can we take before me fail?
Thanks
If you dont know ask one of your kids lol
Not quite sure what you wantr to know- you've answered 87% of 628 calls, so 546.36
Since it has to be an integer, take it to be 546
for you to fall to below 80% of calls, and assuming you answer no more of the calls received from then on, you can answer
546/0.8 = 682.5. Again, can't be an integer, so must be the higher number of 683.
683 - 628 = 55 for you to fall under the 80%.
You can not answer another 54 calls before you fall below the 80% level.
So the real question is, is he calculating if he's got the sack or not? Or asking us to help him calculate when he can slack off?
mate, there is a reason why resource departments have workforce management programs. If you want information on stuff like that go and speak to the one on your site, that way they can tell you more about the metrics that are used and how you lot being lazy effects call stats :p
Ha ha the centre where I work at the customer services staff have to answer 90% of calls in 20 seconds...
thats nothing new or special. it also has less to do with how fast agents answer the phone (as long as ACHT is close) and more to do with how many agents you have answering the calls :p
I never said it was new or special, but it is a harder target to hit than an 80/20 SLA
Of course it is harder, but given a decent resource management it should be easily possible (unless you work in a service provider which could get an influx of calls for a major outage).
Its nothing to do with being lazy. I help out when the calls are mantic but I also have my own job to do. So I need to work out when I have time to do the more time consuming tasks.
As for seeing management, they havent got a clue or I wouldnt ask here. I am sure I can work it out. Just asked as I was doing something at the time and thought someone could be of help.
Thanks for the positive comments.
The question was more on my own time management. So i have to do my work but I help others, but if i worked out where we are safe then i can do other things.
PS There are no macdonalds in my area.
Is that why you needed to know if you had time to drive there? ;):p
Thanks
is it not just 628/87 then multiply that by 100 then multiply that by .8 ?
i got 577
