Weekend Special Deals - Best prices in the UK + Free Saturday Shipping!!!!!
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Here are some truly storming deals for you guys starting now which will end Midday Monday. Also remember you can upgrade to Saturday shipping at no extra cost which means for in stock items you will get them tomorrow:-
Abit IX38 QuadGT Intel X38 (Socket 775) PCI-Express DDR2 Motherboard
You are in the driver's seat with Intel's new enthusiast X38 chipset. Prepare for the latest 65nm and next-generation 45nm Intel Core2 Extreme/Quad/Duo processors with up to 1333FSB. A total of 8GB high-end DDR2 1066Mhz systems memory offers expandability for the latest DDR memory standards. The uniquely abit engineered electrical design including new generation digital PWM's and 100% solid state capacitors provide the best power characteristics resulting in lower consumption, higher efficiency and extreme stability.
- LGA 775
- 45 nm Penryn CPU ready
- Intel® X38 Express
- FSB 1600
- Dual DDR2 1066/800
- Dual PCI-E X16 supporting Crossfire
- SATA 3G RAID
- PCI-E GbE
- Firewire
- 7.1 CH HD Audio
- SilentOTES™
- µGuru™ Tech
- RoHS Compliancy
Price: £99.99+VAT (£117.49 inc VAT)
BUY NOW!
Abit IP35 Pro XE Intel P35 (Socket 775) PCI-Express DDR2 Motherboard
Intel's best processor for multimedia applications with up to 80 percent faster performance for highly-threaded applications and four processing cores to handle the most massive throughput, the Intel Core 2 Extreme quad-core processor provides exceptional performance. With the IP35 Pro you are prepared for the latest 65nm and next generation 45 nm multi-core CPUs. With processors supporting Intel’s SpeedStep Technology (EIST) the IP35 Pro offers even more advanced energy efficiency. Solid State Capacitors significantly reduce heat dissipation and offer best voltage regulation, thereby increasing performance while extending product life and even under most stressful conditions.
- LGA 775
- Intel® P35
- FSB 1600
- Dual DDR2 1066
- PCI-E X16
- SATA 3G RAID
- 2x eSATA 3G
- Gigabit LAN
- IEEE1394
- 7.1 CH HD Audio
- RoHS Compliancy
- SilentOTES™
- µGuru™ Tech
- CMOS Reset Switch
Price: £79.99+VAT (£93.99 inc VAT)
BUY NOW!
GeIL 2GB (2x1GB) PC2-6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC)
GeIL is proud to announced DDR2 800MHz, PC6400 800MHz supports CAS 4-4-4-12 with 1GB and 2GB Dual Channel Kits. These Ultra modules are hand picked for maximum FSB overclocking potential.
- PC6400 800MHz CAS 4-4-4-12
- 64x8 DDR2 BGA Chips
- 240pin, Non-ECC, Un-buffered DDR2 SDRAM DIMM
- Aluminum Heat-spreader
- 6 Layers Ultra Low Noises Shielded PCB
- Lifetime Warranty
- 1.9V-2.3V Power Supply
Price: £23.99+VAT (£28.19 inc VAT)
BUY NOW!
OCZ 2GB (2x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2 (OCZ2P800R22GK)
OCZ PC2-6400 Platinum Revision 2 is the latest version of the Platinum DDR2-800 Series. The PC2-6400 Platinum Rev. 2 has been re-engineered to turn out heart-pounding 4-4-4 timings with flawless performance and stability and offer lower latencies than standard 800MHz DDR2 memory.
OCZ exclusively developed these modules for the extreme gamer and overclocker to give high-end DDR2 based systems that extra performance edge that is demanded by today’s hard core gamers and enthusiasts.
The new OCZ PC2-6400 Platinum Rev. 2 utilizes the latest OCZ heatspreader design. XTC (Xtreme Thermal Convection) Heatspreaders allow increased ventilation and heat dissipation due to an innovative honeycomb design providing more direct access to the actual memory ICs.
As part of the award winning OCZ Platinum DDR2 series, the PC2-6400 Platinum Rev. 2 is built with leading edge technology designed and qualified with special selection of premium components to maximize performance in even the most demanding computing environments. OCZ PC2-6400 products are 100% hand-tested to ensure compliance with stringent quality standards. In addition, each member of the OCZ Platinum family is backed by an industry-leading lifetime warranty, toll-free technical support and the exclusive EVP (Extended Voltage Protection) coverage.
With its ultra-fast performance, high quality and reliability, the OCZ PC2-6400 Platinum Revision 2 edition is a perfect memory upgrade for the latest CPU arrivials.
- 800MHz DDR2
- CL 4-4-4-15 (CAS-TRCD-TRP-TRAS)
- Platinum Mirrored XTC* Heatspreader
- OCZ Lifetime Warranty
- 1.9-2.0 Volts
- 240 Pin DIMM
- OCZ Enhanced Latency Technology
- 2.2V EVP**
BUY NOW!
Kingston HyperX 2GB (2x1GB) DDR2 PC2-8500C5 1066MHz Dual Channel Kit (KHX8500D2K2/2G)
HyperX DDR2 modules are specifically engineered and designed to meet the rigorous requirements of PC enthusiasts. HyperX DDR2 offers faster speeds, lower latencies, higher data bandwidths and lower power consumption than DDR. HyperX is available in single and dual-channel memory kits.
Kingston's KHX8500D2K2/2G is a kit of two 128M x 64-bit 1GB (1024MB) DDR2-1066 CL5 SDRAM (Synchronous DRAM) memory modules, based on sixteen 64M x 8-bit DDR2 FBGA components per module. Total kit capacity is 2GB (2048MB). Each module pair has been tested to run at DDR2- 1066MHz at a latency timing of 5-5-5-15 at 2.2V. The SPD is programmed to JEDEC standard latency 800Mhz timing of 5-5-5-15 at 1.8V. Each 240-pin DIMM uses gold contact fingers and requires +1.8V. The electrical and mechanical specifications are as follows:
- PC8500 1066MHz CAS 5-5-5-15
- Lifetime Warranty
- 2.0V-2.2V Power Supply
Price: £30.99+VAT (£36.41 inc VAT)
BUY NOW!
Kingston HyperX 2GB (2x1GB) DDR2 PC2-9200C5 1150MHz Dual Channel Kit (KHX9200D2K2/2G)
HyperX DDR2 modules are specifically engineered and designed to meet the rigorous requirements of PC enthusiasts. HyperX DDR2 offers faster speeds, lower latencies, higher data bandwidths and lower power consumption than DDR. HyperX is available in single and dual-channel memory kits. Kingston's KHX9200D2K2/2G is a kit of two 128M x 64-bit 1GB (1024MB) DDR2-1150 CL5 SDRAM (Synchronous DRAM) memory modules, based on sixteen 64M x 8-bit DDR2 FBGA components per module. Total kit capacity is 2GB (2048MB). Each module pair has been tested to run at DDR2-1150MHz at a latency timing of 5-5-5-15 at 2.3 - 2.35V. The SPD is programmed to JEDEC standard latency 800Mhz timing of 5-5-5-15 at 1.8V. Each 240-pin DIMM uses gold contact fingers and requires +1.8V. The electrical and mechanical specifications are as follows:
- PC9200 1150MHz CAS 5-5-5-15
- Lifetime Warranty
- 2.3V-2.4V Power Supply
Price: £33.99+VAT (£39.94 inc VAT)
BUY NOW!
OCZ 2GB (2x1GB) PC2-8500C5 1066MHz SLI-Ready Edition Dual Channel DDR2 (OCZ2N1066SR2GK)
New OCZ PC2-8500 Memory Modules are NVIDIA nForce SLI Certified resulting in better performance with select NVIDIA nForce motherboards. The new OCZ PC2-8500 SLI-Ready Series is equipped with NVIDIA Enhanced Performance Profiles (EPP) to optimize the modules’ performance on nForce® 590 SLI-based motherboards. OCZ exclusively engineered select high-performance modules with advanced SPD (Serial Presence Detect) settings to allow compatible motherboards to recognize and utilize the added information, ultimately increasing the performance potential of the entire platform. OCZ SLI-Ready memory modules are programmed to boot at 1066MHz DDR2 with supremely fast timings of 5-5-5. Only motherboards equipped with the custom-designed BIOS, such as those designed for NVIDIA nForce 590 SLI MCPs, can detect the optimized SPD profiles and ensure the memory functions under the best possible conditions. The exclusive OCZ SPD specifications take out the guesswork and provide enthusiasts and gamers with significant overclocked performance with no manual adjustment or compatibility issues. Each OCZ SLI-Ready module comes equipped with an exclusive NVIDIA XTC heatspreaders for the most efficient heat dissipation and a look that stands out like its performance. Additionally, all SLI-Ready memory is backed with toll-free technical support, the exclusive EVP (Extended Voltage Protection) coverage, and an industry leading Lifetime Warranty. With the fusion of the sophisticated EPP memory specification and cutting-edge, high-speed OCZ DDR2 architecture, the PC2-8500 edition is the ultimate breakthrough for advanced SLI platform performance.
- 1066MHz DDR2
- EPP 5-5-5-15 (CAS-TRCD-TRP-TRAS)
- Unbuffered
- SLI-Ready XTC Heatspreader*
- Lifetime Warranty
- 2.1 Volts
- 240 Pin DIMM
- NVIDIA® SLI™ certified
- 2.4V EVP**
BUY NOW!
Leadtek GeForce GTX 260 896MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail
Get pulled deeper into the gaming experience than ever before with next generation NVIDIA GeForce GTX 260 GPU. GeForce GTX 260 make games including Unreal Tournament 3, Assassin’s Creed, Call of Duty 4: Modern Warfare and S.T.A.L.K.E.R.: Clear Sky – feel like the real thing. High definition worlds crackle and hum with cinema-quality clarity. Lifelike characters behave with such realistic intensity that your palms sweat and your heart races. Objects react to the forces of nature exactly as nature intended. And with 50% better performance than previous generation graphics processors, you get it all...No lag. No dropped frames. No compromises. Beyond the field of play, the GeForce GTX 260 GPU seamlessly shifts intense processing tasks from the CPU to the GPU. Dive into the latest Blu-ray movie, run the Folding@home protein folding application to help cure diseases, browse your favorite web sites in 3D with PicLens, or transcode video to a personal video player up to 7X faster than the CPU.
- Bus Type: PCI Express 2.0 (Backwards compatible with PCI Express)
- Memory: 896MB GDDR3
- Core Clock: 576MHz
- Shader Clock: 1242MHz
- Memory Data Rate: 1998MHz
- Processor Cores: 192
- Shader Model: 4.0
- Texture Fill Rate: 36.9 Billion/sec.
- Memory Interface: 448-bit
- Memory Bandwidth: 111.9GB/sec.
- API Support: Microsoft DirectX 10 and lower, OpenGL 2.1 and lower for Microsoft Windows
- Display Connectors: 2 Dual-Link DVI-I, HDTV + TV Out
- RAMDACs: Dual 400MHz
- HDCP Capable
- HDMI Capable
- 2-Way & 3-Way NVIDIA SLi Support
- Card Dimensions: 266.7mm x 95.3mm x 38.1mm
- Warranty: 2 Year
Price: £159.99+VAT (£187.99 inc VAT)
BUY NOW!
Leadtek GeForce GTX 280 1024MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail
Get pulled deeper into the gaming experience than ever before with next generation NVIDIA GeForce GTX 280 GPU. GeForce GTX 280 make games including Unreal Tournament 3, Assassin’s Creed, Call of Duty 4: Modern Warfare and S.T.A.L.K.E.R.: Clear Sky - feel like the real thing. High definition worlds crackle and hum with cinema-quality clarity. Lifelike characters behave with such realistic intensity that your palms sweat and your heart races. Objects react to the forces of nature exactly as nature intended. And with 50% better performance than previous generation graphics processors, you get it all...No lag. No dropped frames. No compromises. Beyond the field of play, the GeForce GTX 280 GPU seamlessly shifts intense processing tasks from the CPU to the GPU. Dive into the latest Blu-ray movie, run the Folding@home protein folding application to help cure diseases, browse your favorite web sites in 3D with PicLens, or transcode video to a personal video player up to 7X faster than the CPU.
- Memory: 1GB (1024MB) GDDR3
- Core Clock: 602MHz
- Shader Clock: 1296MHz
- Memory Data Rate: 2214MHz
- Processor Cores: 240
- Shader Model: 4.0
- Texture Fill Rate: 49.2 Billion/sec.
- Memory Interface: 512-bit
- Memory Bandwidth: 141.7GB/sec.
- HDCP Capable
- HDMI Capable
- Warranty: 2 Year
Price: £229.99+VAT (£270.24 inc VAT)
BUY NOW!
XFX GeForce 8800 GTX XXX 768MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail (PV-T80F-SHD9)
The 8800 series is the world's first DirectX 10 graphics card with full Shader Model 4.0 support. It delivers unparalleled levels of graphics realism and film-quality effects. Even more, it also supports the NVIDIA Lumenex™ engine to give unsurpassed image quality, floating point accuracy, and fast frame rates. Built for Windows Vista™, the 8800 series ensures the best possible performance when running the Windows Vista 3D graphical user interface. The 8800 series complies with many cutting-edge Xtreme-HD features. It provides two Dual-Link DVI connections to support two hi-end, ultra-large, 30-inch LCD monitors at a mind bending 2560x1600 resolution. With an embedded revolutionary HDTV encoder, the 8800 series also supports crystal clear HDTV output up to 1080i. On top of this, it enhances compatibility with other video standards, delivers hitherto undreamt of clarity, smooth video, accurate color, and precise image scaling for all video content such as MPEG-2, WMV, WMV HD with NVIDIA exclusive PureVideo™ HD technology. What's more, playback of HD DVD, Blu-ray Disc, and other protected content at full HD resolutions with integrated High-bandwidth Digital Content Protection (HDCP) is fully supported. The WinFast® PX8800 series complies with many cutting-edge Xtreme-HD features. It provides two Dual-Link DVI connections to support two hi-end, ultra-large, 30-inch LCD monitors at a mind bending 2560x1600 resolution. With an embedded revolutionary HDTV encoder, the 8800 series also supports crystal clear HDTV output up to 1080i. On top of this, it enhances compatibility with other video standards, delivers hitherto undreamt of clarity, smooth video, accurate color, and precise image scaling for all video content such as MPEG-2, WMV, WMV HD with NVIDIA exclusive PureVideo™ HD technology. What's more, playback of HD DVD, Blu-ray Disc, and other protected content at full HD resolutions with integrated High-bandwidth Digital Content Protection (HDCP) is fully supported.
- GeForce 8800 GTX core running at 630MHz
- Shader Clock Speed of 1350MHz
- 768MB GDDR3 Memory running at 2000MHz
- 384-Bit Memory Interface
- 128 Stream Processors
- Shader Model 4.0
- Texture Fill Rate: 36.8 billion/sec
- Memory Bandwidth: 86.4GB/s
- Designed For Extreme HD Gaming
- Nvidia Pure Video Technology
- Dedicated Video processors free the GPU Shaders to run 3D applications
- Dual dual-link DVI supports two 2560 x 1600 resolution displays
- HDCP Enabled!!
- SLI ready – Upto 2x the performance of a single GPU (Available on with future driver release)
- True High Dynamic Range Rendering Support – Based on Open EXR technology
- World's first unified architecture supporting Microsoft® DirectX® 10
- Built for Microsoft® Windows® Vista™
- 2yr Warranty with OcUK direct (For XFX warranty contact OcUK for RMA and we will endeavour to resolve your problem within 7 working days)
Note: This card is 275mm in length so make sure it fits in your case! Also the cards require PCI-E x16 slots, they will not function in a x8 slot so for SLi you need dual x16 mainboard. Finally 500W minimum for PSU and 600W+ is recommended.
BUY NOW!
XFX GeForce 8800 GT Alpha Dog 512MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail (PV-T88P-YDF4)
Your search for the perfect graphics card is over. The ideal combination of power, performance, and price, the NVIDIA® GeForce® 8800 GT graphics card offers 112 stream processors, a 512MB 256-bit frame buffer, standard-setting GeForce 8 Series features and, a strikingly immersive DirectX 10 gaming experience. Ultra-realistic smoke, rain, explosions, lighting, terrain deformation and motion blur enable jealousy-inducing, lightning-fast gameplay in the hottest games, including Crysis, Hellgate: London, Call of Duty 4, and Gears of War. With full support for PCI Express 2.0 and featuring second generation NVIDIA PureVideo™ HD engine, the SLI™-Ready NVIDIA GeForce 8800 GT graphics card was worth the wait.
- GeForce 8800 GT core running at 600MHz
- Shader Clock Speed of 1500MHz
- 512MB GDDR3 Memory running at 1800MHz
- 256-Bit Memory Interface
- 112 Stream Processors
- Shader Model 4.0
- Memory Bandwidth: 57.6GB/s
- HDCP Enabled!!
BUY NOW!
Zotac GeForce GTX 280 AMP 1024MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail
- Core Clock: 700MHz
- Memory Data Rate: 2300MHz
- Shader Model: 4.0
- HDCP Capable
- HDMI Capable
- Includes Codemasters GRID Game
- Warranty: 5 Year
Price: £274.99+VAT (£323.11 inc VAT)
BUY NOW!
Leadtek GeForce 9800 GX2 1024MB GDDR3 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail
Beautifully designed and engineered for extreme power, the Leadtek NVIDIA® GeForce® 9800 GX2 1GB graphics card is The Console Within - a complete, high definition entertainment and gaming solution for the PC. With NVIDIA HybridPower™ technology and two on-board GPU's, the Leadtek NVIDIA® GeForce® 9800 GX2 is bar-none the fastest graphics card available and up to 50% faster than GeForce® 8800 Ultra. When paired with an additional Leadtek NVIDIA® GeForce® 9800 GX2-based graphics card and an NVIDIA nForce® 7 Series motherboard, this Quad NVIDIA SLI® technology solution creates the most awe-inspiring, screaming fast gaming platform to date. Be blown away by scorching frame rates, true-to-life extreme HD gaming, a picture-perfect HD DVD and Blu-ray Disc® movies with ultra-smooth playback.
- GeForce 9800 GX2 core running at 600MHz
- 1024MB GDDR3 Memory running at 2000MHz
- 512-Bit Memory Interface
- 256 Stream Processors
- Shader Model 4.0
- Texture Fill Rate: 76.8 billion/sec
- Memory Bandwidth: 128GB/s
- Up to 50% faster than GeForceR 8800 Ultra
- Display Connectors: 2 Dual-Link DVI-I, HDMIR Out
- HDCP Capable, HDMIR Capable
- HDCP Enabled!!
- SLI ready
- 2yr Warranty with Leadtek/OcUK
Note: This card is 295mm in length so make sure it fits in your case! Also the cards require PCI-E x16 slots, they will not function in a x8 slot so for SLi you need dual x16 mainboard. Finally 600W minimum for PSU and 700W+ is recommended. Also make sure your PSU has true 8 pin PCI-Express connector rather than a 6+2 pin connector.
Price: £197.99+VAT (£232.64 inc VAT)
BUY NOW!
Sapphire ATI Radeon HD 3850 Pro 512MB GDDR3 TV-Out/Dual DVI/HDMI (AGP) - Retail
Delivering Mayhem to the Mainstream Long thought to be the market of the conservative gamer, the affordable mainstream products, which use to suffer only adequate performance, now experiences a frame rate revival with the SAPPHIRE HD 3850. Built upon the award winning Radeon HD 3850 core, the SAPPHIRE 3850 offers a comprehensive feature-set that eclipses previous and current mainstream offerings. Unleash the enthusiast inside you with support for advanced technologies such as DirectX® 10 and Shader Model 4 support, integrated HDCP support for Blu-ray™/HD DVD decoding and for extreme enthusiast, Jam a SAPPHIRE HD 3850 into your rig and still have some coin left over to buy that title you have been waiting for!
- Powered by Radeon® HD 3850 GPU @ 668MHz
- 512MB(256bit) GDDR3 memory @ 1656MHz
- Superscalar unified shader architecture
- 320 stream processing units
- 256-bit memory interface
- DirectX® 10.1 / Shader Model 4.1 support
Price: £74.99+VAT (£88.11 inc VAT)
BUY NOW!
Sapphire ATI Radeon HD 4870 512MB GDDR5 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail
The ATI Radeon HD 4800 Series GPUs bring the power of graphics ‘supercomputing’ to gamers, setting a new standard for visual computing. Redefine the way you play and take HD gaming to the extreme with best-in-class performance. The new TeraScale graphics engine delivers an immersive, cinematic gaming experience. Add this GPU to your PC and watch Blu-ray movies and play HD content with incredible visual fidelity. Do it all with break-through efficiency that doesn’t compromise performance.
- ATI Radeon HD 4870 GPU @ 750MHz
- 512MB GDDR5 Memory @ 3600MHz
- 24x custom filter anti-aliasing (CFAA) and high performance anisotropic filtering
- PCI Express 2.0 support
- ATI CrossFireX Multi-GPU Technology
- Microsoft DirectX 10.1 support
- Shader Model 4.1
- ATI Avivo HD video and display technology
- Unified Video Decoder 2 (UVD) for Blu-ray and HD Video
- Built-in HDMI with 5.1 surround sound support
- On-chip HDCP
Price: £149.99+VAT (£176.24 inc VAT)
BUY NOW!
PowerColor ATI Radeon HD 3870 X2 "Special Edition" 1024MB GDDR4 TV-Out/Triple DVI/HDMI (PCI-Express) - Retail
Advance to ultimate HD gaming with incredible performance, life-like graphics and support for Microsoft® DirectX® 10.1. With dual ATI Radeon™ HD 3870 GPUs working in exquisite precision, you’re ready to dominate the battlefield from over one teraFLOPS of GPU compute power. And thanks to plug-and-play ATI CrossFireX™ upgradeability, you can scale your performance to even greater heights. ATI PowerPlay™ technology first used in ATI Mobility Radeon™ notebook GPUs has been built into the ATI Radeon™ 3800 Series GPU. This exciting break-through technology delivers further on AMD’s commitment to reducing the energy consumption in computing technologies. The technology is designed to enable power saving profiles that help reduce power consumption when the GPU is idle or in minimal use in comparison to previous products. This dynamic power management enables the GPU to automatically adjust power between low, medium and high states. It can alter the engine and memory clocks, as well as the voltages based on the software application’s activity level. Connect your PC to your home theater and start watching HD content from your computer using new ATI Radeon™ HD 3800 series graphics cards. The ATI Radeon™ HD 3800 Series is designed to decode and playback Blu-ray™ and HD DVD formats using dedicated hardware within the GPU. This technology, known as UVD or Unified Video Decoding, is part of ATI Avivo™ HD, the new collection of technologies that are designed to improve the visual and connectivity capabilities of ATI Radeon™ HD 3800 Series GPUs. UVD offloads the intensive process of HD video decoding and playback from the CPU while improving the visual quality. This means you can get smooth, high quality HD video playback from entry level PCs or free up the CPU for other tasks while you enjoy the movie. And with HDCP built into the GPU, the new cards easily enable playback of protected content. The ATI Radeon™ HD 3800 Series GPU further enhances the HD entertainment experience by making it easy to make the connection to a big- screen or home theater system. With built-in 5.1 surround audio (AC3) pass-through capabilities, the new GPUs and graphics cards support a single HDMI connection direct to a compatible TV or receiver. This single cable carries both the HD video and 5.1 surround audio for a clean, high definition connection. Some graphics cards will have an HDMI connector built in, while others will use a special ATI Radeon DVI-I to HDMI adapter. These options mean greater choice and flexibility for consumers when connecting to PC monitors or home theaters for maximum enjoyment of full HD 1080p content. New ATI CrossFireX™ multi-GPU technology takes your gaming experience to the next level with more scalability, performance and compatibility. The technology combines the awe-inspiring capabilities of multiple ATI Radeon™ graphics cards and an ATI CrossFireX ready motherboard to meet the hard-core demands of your alternate reality. New ATI Radeon™ HD graphics cards are designed with an internal ATI CrossFireX™ Bridge Interconnect system to simplify installation. Experience stunning visual realism in today’s demanding 3D games with uncompromising image quality, especially on HD displays. ATI CrossFireX: Multiply and Conquer!
- Dual-GPU technology – Don’t fear cranking up the settings - with dual ATI Radeon™
battlefield.
- Over 1 teraFLOPS of GPU compute power - 640 stream processors (320 x 2) deliver
the raw horsepower to attack the most demanding graphics applications.
- Incredible performance – You’ll be blown away by life-like graphics from the latest
Microsoft® DirectX® 10.1 games, with stunning 3D graphics and shading effects.
- ATI CrossFireX™ – Scale your 3D performance to greater heights quickly and easily with
plug-and-play ATI CrossFireX technology that supports up to four GPUs.
- More processing performance per watt – the ATI Radeon™ HD 3800 Series
- GPUs deliver up to twice the Gigaflops per watt of previous generations of AMD GPUs.
- 2 x ATI Radeon R680 Cores running at 825MHz
- 3 x DVI Connections
- 1024MB GDDR4 Memory running at 2250MHz
- Over 1 TeraFLOPS of GPU Compute Power
- 640 (320 x2) stream processing units
- 2 x 256-bit memory interfaces
- Dynamic geometry acceleration
- Game physics processing capability
- ATI CrossFireX™ multi-GPU support for highly scalable performance
- Use up to four GPUs with an AMD 790FX based motherboard
- High-speed 128-bit HDR (High Dynamic Range) rendering
- Up to 24x Custom Filter Anti-Aliasing
- ATI Avivo™ HD video and display technology*
- Built-in HDMI and 5.1 surround audio
- Support for the ATI Radeon™ DVI to HDMI adapter
- Unified Video Decoder (UVD) for Blu-ray™ and HD DVD
- ATI PowerPlay™ energy conserving technology
- ATI Avivo™ HD is a technology platform
Price: £134.99+VAT (£158.61 inc VAT)
BUY NOW!
Tuniq Tower 120-LFB CPU Cooler (Socket 478/754/939/940/AM2/LGA775)
The Tuniq Tower 120 CPU Cooler features a unique design placing the fan in the centre of cooler which offers better performance than a regular fan mounted on the outer of the heatsink. The three-heatpipe design offers superb heat dissapation and the large amount of fins provide maximum cooling performance.
- Socket Type: 478 / 754 / 939 / 940 / AM2 / LGA775
- Dimensions: 131mm x 108mm x 153mm
- Fan Dimensions: 120mm x 120mm x 25mm
- Fan Connector: 3-Pin
- Fan Speed: 1000 - 2000 RPM
BUY NOW!http://www.overclockers.co.uk/showp...PU Cooler (Socket 478/754/939/940/AM2/LGA775)http://www.overclockers.co.uk/showp...PU Cooler (Socket 478/754/939/940/AM2/LGA775)
Akasa Omega Aluminium Case - Black
The coolest case ever just got cooler just got cooler! Omega is the ultimate evolution of the famous Akasa Eclipse hi-engineered PC case. The spacious interior has been redesigned with water-cooling in mind and a solid aluminium front door creates an impressive looking chassis with excellent cooling capabilities. Full height mesh ventilation in the front and up to six 12cm fans provide a unique system cooling performance. Top and side panels are redesigned to accommodate two 12cm fans and water-cooling radiators. Top, sides and front panels are removable to ensure unrestricted access from all sides and the mirror-finish stainless steel removable motherboard tray enables you to build your system outside with ease and then slide into the chassis. Six easily accessible I/O ports mounted on the side of the front panel include HD Audio and eSATA. The inside of the front door is recessed enabling installation of 5.25” devices with extended dials or control knobs (i.e AK-FC-03). An internal mounting bracket secures the PSU and prevents any vibration. The optional maxi-view panel (AK-BKWSP-01) is also available for the OMEGA case.
- Anodized Smooth black
- Chassis frame 1.5mm aluminium
- Removable side and top panels 1.2mm aluminium
- Front panel 3.0mm aluminium door with ABS structure
- Slide-out motherboard tray Mirror finish stainless steel
- Compatible motherboard types ATX, Micro ATX & Extended ATX
- 5.25'' external bays 4
- 3.5'' removable external bays 2
- 3.5'' removable internal bays 5
- Fans included Two 120x25mm fans (front and rear)
- Fan Speed 1200 RPM
- Fan airflow 47.98 CFM
- Fan noise 23.1 dB(A)
- Dust management Washable air intake filter
- USB ports 2
- IEEE1394 ports 1
- HD Audio 1 in / 1 out (AC’97 backwards compatible)
- eSATA ports 1
- Dimension 460 x 240 x 560mm (H x W x L)
- Weight 8.6kg
Price: £104.99+VAT (£123.36 inc VAT)
BUY NOW!
OcUK Value L2442WD-VA 24" Widescreen LCD Monitor - Glossy Black
The OcUK Value L2442WD has an industry leading ultra-fast 6ms GtG response time making it perfect for blur-free video and gaming. With it's 1000:1 contrast ratio and excellent viewing angles there is no other TFT/LCD that can match the quality, value or performance. Make the large screen affordable to all this 24" is ideal for gamers and professional users who require a high resolution screen capable of delivering very impressive quality and extreme viewing angles due to the use of a VA panel within these monitors.
- 1920 x 1200 (WUXGA) Optimum Resolution
- 16.7 Million Colours
- 1000:1 Contrast Ratio
- 6ms Response Time
- 500 cd/m2 Brightness
- Viewing Angle (H/V): 180°/ 180° (VA Panel)
- One Digital Input (Supplied with DVI Cable)
- One Analogue Input (Supplied with Analogue Cable)
- Supplied with both Analogue and DVI cables
- Wall Mountable
- Built in stereo speakers
- Warranty : 3 year on-site collect and return warranty supplied by Manufacturer (Call DGM direct for all support and RMA issues on 0871 2508000)
Price: £179.99+VAT (£211.49 inc VAT)
BUY NOW!
Samsung SM-245B PLUS 24" Widescreen LCD Monitor - Black
Imagine having elbow room on screen. That’s exactly what you get with the Samsung 245B series of widescreen LCD monitors. Wide 16:10 aspect ratios let you multitask, with room for more than one application at a time. The extra room also makes working with graphics programs and multiple tool palletes easier. An ultra-fast 5 ms (G to G) response time is perfect for motion graphics editing. And exclusive MagicBright 3,™ MagicColor™ and MagicTune™ technologies give you complete control over outstanding color. All the color. All the room. With the Samsung 245B, it’s not hard to imagine.
- Viewable Area: 24” Widescreen (1920x1200 Resolution)
- Interface: Analog / Digital
- Response Time: 5ms
- 16.7M Colours
- Contrast Ratio: 8000:1
- Viewing Angle (H/V): 160°/ 160°
- Brightness: 400cd/m2
- Height Adjustable stand with tilt & swivel
- 3 Years On-Site Warranty with Samsung
Price: £239.99+VAT (£281.99 inc VAT)
BUY NOW!
OcUK Value Hanns-G HG281DP 28" Widescreen LCD Monitor - Black
The OcUK Value HG281DP has an industry leading ultra-fast 3ms GtG response time making it perfect for blur-free video and gaming. With it's 800:1 contrast ratio and excellent viewing angles there is no other TFT/LCD that can match the quality, value or performance. Make the large screen affordable to all this 28" is ideal for gamers and home cinema use due to its huge 28" size and 1920x1200 resolution.
- 800:1 Contrast Ratio
- 3ms Response Time
- Viewing Angle (H/V): 170°/ 170°
- One HDMI Input (Supplied with HDMI to DVI lead for connection to DVI on PC)
- Integrated Speakers (2.5W x2)
- 3 Years Manufacturer On-Site Warranty (Call Manufacturer direct on 0871 8552425)
BUY NOW!
*** TODAY ONLY - Saturday Delivery at Weekday Prices ***
*** Amazing Full System Deals for This Week Only ***
Systems updated and reduced in price including GTX 280 and HD 4870 Systems
*** This Week Only Deals!! ***
This is why I need to stop coming to these forums. Just tempts me to spend money I don't need to :(
Though upgrading to X38 board and trying out 4870 in crossfire would be so lovely to place with.... even though my current 4870 hardly sees any gaming.
Great prices.
Bit livid TBH, i just got a 4870 sapphire delivered yesterday and now the price comes down. May have to send it back to re-order at cheaper rates as its an expensive present.
GTX price is incredible! SLI is extremely tempting now!
Good on you Gibbo
I'll only order if you guarantee I get the girl in cream to deliver it?
I knew I shouldn't have ordered earlier! Oh well, OcUK won another £91 of mine. Thats £600 in 3 weeks :( :p
no harm in giving them a call if your purchase was very recent and just before a price change mate :)
I'm tempted my one of those 8800GTXs. Think there's any point for 1280x1024?
Not really over the GT. Sure, it will make a little bit of diff in Crysis, but everything else should run fairly well already at 1280, and you would not notice that much of an improvement I don't think.
