Well, I've had both for 3 days now, and have had a chance to do a little gaming, so thought I'd give my first impressions. Hopefully a nice neutral post rather than 'omg ATI r0x0rs my b0x0rs NV cheat and steal babies' or 'NV pwn all NV rule the world, ATI drivers suck'.
I think I'll present my findings in easy to read bullet points:
- During BIOS/Windows bootup, the resolution output seems to be 4:3 with ATI, 16:10 with NV. It seems NV cards decide that very low resolutions should be scales automatically whereas ATI just outputs what it receives. +1 to ATI cause the stretching is annoying, my monitor is set to scale with the correct aspect ratio not warp everything into a mess.
- ATI's CCC is much improved over how it used to be. It hasn't crashed on me, and it's better laid out. +1 to ATI.
- NV's handling of monitors is both more logical and easier. ATI have all sorts of weird, pointless options to work around issues / bugs with high resolution digital displays. +1 to NV
- NV allows for automatic profiles associated with games. Pretty cool, but annoying that you have to set the same settings for different games over and over. ATI you create a profile, and then apply it from the right-click menu. Both have their faults and improvements. Tie.
- ATI's drivers are more aggressive re. applying their settings to games. FSAA in UT3? Yes please! +1 to ATI, bigtime.
- ATI's transparancy AA is pure bliss, love it. +1 to ATI
- Narrow-Tent causes a big performance drop. -1 to ATI for breaking something that worked well on the 2900XT.
- NV has more AA modes, and they're all useful in different games. ATI its restricted to just box and edge, the other modes are too slow. +1 to NV
- NV has WAY fewer driver bugs re. games. +1 to NV
- Neither cards have crashed or caused unneccesary agro. Tie.
Now for performance:
- Anyone who says the 4870 1GB can outperform the GTX 280 is kidding themselves. Both cards perform well, but with the 4870 you're never sure what kind of performance you'll get in a game. However, with the 280 it's so consistent you know how it'll perform, and with difficult settings the 280 is much better. So basically you know with a 280, you can play anything with high detail and AA. The 4870... not so much.
- Crysis performs predictably better on the 280.
- Stalker: Clear Sky performs about the same in actual playability - but there seems to be some graphical anomolies with ATI.
- FEAR runs ludicrously well on the Radeon, stupendously well.
- 280 performs better in Mass Effect, esp when AA is applied. No framerate counters - going purely on responsiveness and smoothness.
Now for noise:
The 4870 1GB model I got is the one with dual fans as offered by Palit / Gainward / Xpertvision (Palit own Gainward and Xpertvision). At idle both the 280 and 4870 are for all intents and purposes, silent. I have 3 low-speed 120mm fans in my case, and its no noisier than them. At load the 280 can vary between barely registering, to really quite noisy. It's never horrible, but you do get a lot of wind sound. If you play a graphically intense, silent game, it could bother you. It bothers me a little. The 4870 stays quiet, it will spin up a little. The first notch it spins up to the pitch increases and it can be very slightly annoying, then it spins up slightly more, the pitch falls back down, and it's basically silent again. Quite odd.
In summary, both are great cards. If I could only have one, and the price difference didn't matter, I would definitely get the 280. However, the 4870 definitely punches above its price point. Very well priced.
Pretty picture of the card:
Excellent info Boogle, I'm still sitting on the fence between these two. What about temps? I'm still concerned about some of the temps with the 280.
*translates*
*dies*
