about mine.
Once I get back the motherboard for the new build I'll attempt to keep it tidy, not making any promises to myself though.I thought you bought a Q6600? It's multiplier is 9 isn't it? 9x400=3.6ghzOK, that was the easiest overclock ever... Set it to 08.0 ratio and 400 FSB and... 3.2GHz, done, no messing about. All tested fine, no faults so far. I'll run a full burn-in tonight, but preliminary tests look all perfect!![]()
Yup! I dropped the multiplier to 8 and stuck it at 400Should be a nice stable overclock I hope!
Wow! So intel no longer multiplier lock?
Have you tried the full 9x400 out of interest? Can you go 8.5x400 out of interest?
Can't do .5x on these. It should do 9x400 with a vcore increase but it may be too much extra voltage for the gain to be worthwhile. More volts mean more heat for these power hungry quads. I had one whose sweet spot was 8x450. It loved the extra bandwidth. It went on to do 3.8Ghz but it was a waste of time for me. My main rig is just for gaming and it left three cores churning out heat and sucking up voltage but doing nothing. It's different for him as he has that x2 which needs a quad to be set free.
I just want to make a note that this was an early christmas present from my lovely wife, although I sense she might have done it to keep me out of the way
I need to show the girlfriend this thread. "Look what he got, now if you really loved me"
What's the fastest the FSB can be set to on a P5Q then? 450? In such a case what is the memory running at?
OK, so I've run a full 8 hour burn-in now, and I can say without a shadow of a doubt that this overclock is 100%. I don't know if I got lucky with the chip or what, but I never exceeded 80 degrees on full load.
Played Crysis on maximum everything earlier on 1920x1200 and I didn't drop below 50fps.
This is the rig I always dreamed of, can't wait for Fallout 3 and Deadspace. Finally I have a rig worth writing home about![]()
