It will be fairly small stuff, I was told to get those big, tall tanks?
not really, never done it before, as anything it comes with practice.If it is small, then you should really be fine with a single gas. Propane or butane should be fine (nigh on exactly the same burn temperature in air).
Are you doing much soldering? Have you silver soldered before? I've been doing it on and off for the last 7 years or so, and I still balls it up occasionally.
