Attn speakers of the German language!
Caporegime
19 Apr 2008
Essex
Could someone translate this email for me, i have tried google translate and babel fish but they dont make much sense.
help :confused:
Hallo...
habe viglen dossier ns 1000Mhz...problem: geht nicht an,power led blinkt,lüfter lauft auf halben touren...
was kann das sein???
mit freundlichen grüssen
Erstellt von
Vitalij Knyschow
Google translate does a fair job of the 2nd bit...
"Hello ...
've viglen dossier ns 1000Mhz ... problem: is not acceptable, LED flashes, fans running on half a tour ...
what can that be?
Yours sincerely.."
Whatever you've sold him (presumably a Viglen laptop) doesn't appear to be working...
So, so far we know that it's Viglen, and the LED flashes with fans running
and ITS NOT ACCEPTABLE!
Viglen Dossier appears to be a brand of laptop. Lufter is a fan.
So, I have a Viglen Dossier NS 1Ghz. Problem: it doesn't turn on. The power LED blinks, fan runs, and half starts (I think). What could it be?
With friendly greetings,
help :confused:
Hallo...
Erstellt von
Vitalij Knyschow
Won't switch on, power LCD blinks, fan is running at half speed/half rotations
I thought it was that except, 'Power LED blinks, fan turns halfway [and then stops, presumably]'
dont worry, all the WW1/2 jokes have been wheeled out!
In that case could somebody please translate the following into passable german, there's free cake in it! (collection from N. London only)
Dear Sir,
It is likely that this issue is caused by dry solder joints on the BIOS chip, as the laptop is almost certainly out of warranty due to the age of the model. I would recommend that you take the laptop into electronic service centre and they will be able to resolder the contacts on the motherboard.
Regards,
___________________________
Lieber Herr Knyschow,
Dieses Problem ist wahrscheinlich durch trockene Lötstelle auf dem BIOS-Chip verursacht. Da der Laptop wegen seines Alters höchstwahrscheinlich nicht mehr gewährleistet ist, würde ich Ihnen empfehlen, der Laptop in ein Elektronikdienstleistungszentrum zu bringen, wo die Kontakte auf dem Motherboard wiedergelötet werden können.
Mit freundlichen Grüßen,
Janesy B
My technical German isn't so good, but that should be about right :)
Hallo...
Erstellt von
Vitalij Knyschow
Attention
Sound the alarms, the allied forces are coming for us!!
Yours faithfully
