My PC I7 with Pics
Permabanned
4 Nov 2008
Earth :-)
Just got my other 280gtx today from bfg company after i had to RMA it for running in 8x instead of 16x...everything is good now!
re
i have crammed as many cables as i can behind the other side of the tower...i cannot do anymore:)
my case is ultra cool,i actually feel a chill of it when sitting by it...so im happy with it
re
yeah it does get hotter than normal but according to everest which i have running all the time,my card idles between 45 and 55 depending on room temperature..at full load ie:farcry 2 with everything set to ultra high at resolution 1920*1080 the temps goes up to 75,i have rivatuner fan speed set to 60% so my pc is still very quiet....its not a problem to be honest :)
basically because the card is so close to the other one i get an extra 10 degress increase more than normal......75 instead of 65 degrees
re
idle 45-50....full load 75(farcry2 ultra high,every setting on full,1920*1080 res)
Ill tkae a look at your thread
i just checked your thread...the rampage 2 board is bigger and covers the hole in the middle of the antec 1200 so i cant fit any cables through here...not only that but the sata connectors on the mobo are located here so the small space i have is taken up by these...i have studied my case and tried to thinkk of ways to hide more cables but i cannot as all the holes are already ful with cables going out through them and down the other side of the case....i think i have done a good job on it for a first time build:)
Also you have that big power cable going across your board,i managed to hide that on mine :-)
That a shame. This case is not really that good for most things imo but what makes it what it is is the awsome cooling.
I did consider cutting some new holes... have you thought about that?
If you go to page 2 of my thread you will see V2 where I bought an 8 pin extension and spent hours on the wiring.
looking good m8 seems a lot of peeps went for the gtx 280 even though so many were ranting about the 4870 x2, wish i had gone that road now
Here is my bios which i meant to post a while ago...this is 3.8 and its rock solid,very stable
This is pictures from bios 1001
I am currently using bios 1101
i have exactly the same settings in the new bios 1101,i have found with bios 1101 i can lower my cpu voltage a little more than i had in bios 1001 that you see in the pictures.....
my cpu voltage in bios 1001 in the pictures is 1.375v....but in the bios 1101 that im using now i have it set at 1.350v....its a little lower and gives me the same results and is very stable....1.350v i tried in bios 1001 and it failed to boot into windows
This is for the rampage 2 board
