Anand: PII vs. Q9550 vs. i7 crossfire, Phenom II = smoother
7 May 2006
London, Ealing
Originally Posted by anand
During testing, the Intel systems would generate minimum frame rates at this resolutions about 23~24fps on a couple of runs and then jump to their current results on the others. We noticed this in game play also; the Intel systems would hitch and pause at times. We would shutdown the game, clear the prefetch folder, and reboot. The game would operate fine in the next series of testing although we still had stuttering in intensive ground scenes at times. We tried new images, different CPUs, memory changes, and the Sapphire HD 4870 cards with the same results. The Phenom II 940 had extremely stable frame rates in each test and action was very fluid during game play.
After playing through the several levels on each platform, we thought the Phenom II 940 offered a better overall gaming experience in this title than the Intel Q9550 based on smoother game play. It is difficult to quantify without a video capture, but player movement and weapon control just seemed to be more precise. Of course, if you have the funds, we would recommend the i7 platform for best possible performance.
The Phenom II is slightly ahead of the Q9550 when overclocked although it is at a 7% clock speed disadvantage. We have noticed the CryEngine 2 will respond to improved memory bandwidth and latencies as we clock up the processors. The i7 holds a 14% advantage in average frame rates while the Phenom II once again impresses us with the best minimum frame rates when overclocked. However, not having a 20fps minimum frame rate is a disappointment with our multi-GPU setups. The NVIDIA 260/285 solutions scale better in SLI than the ATI HD 4870 products. We hope that ATI can improve their drivers for this game.
Now that we have discussed the numbers, what about game play experience? As we alluded to earlier, the Intel platforms had problems with minimum frame rates throughout testing, not just in the benchmarks, but also during game play in various levels and on-line. We have not nailed it down yet, but we have noticed this problem consistently. In the meantime, the Phenom II X4 940 had rock solid frame rates and offered the smoothest game play experience.
http://www.anandtech.com/mb/showdoc.aspx?i=3506&p=1
However, looking through the performance results and game play experiences, we have to mention just how fast Intel's Core i7 is right now. It’s results were just remarkable in Far Cry 2 and it consistently scored at the top in CrossFire mode in the other games even though it has the lowest core clock speed. If platform pricing were better, then the Core i7 series would have a clear recommendation for an upgrade if you were considering a multi-GPU setup.
Margarine is smoother than butter but we all know what tastes the best.
I actually think Phenom II offers good performance when compared to equivalently priced competition. When you consider CPU, Mobo and Ram costs, the i7 platform is only an option for those that have money to waste.
"We noticed this in game play also; the Intel systems would hitch and pause at times. We would shutdown the game, clear the prefetch folder, and reboot."
It sounds more like a Vista caching issue, I would've thought a reputable review site like Anandtech would turn off the Superfetch service when benchmarking to stop it from randomly interfering.
Using an NVidia GPU would've been more sensible also their drivers aren't as buggy.
I would say its not a waste if you really want the best.
It does not do it with an AMD CPU which is the point.
Using a NV gpu is irrelevant when its about the CPU performance against CPU.
Oh gawd, another "P2 is smoother" thread, P2 fails compared to i7 in raw speed, and any test on a FULLY optimised engine would prove that.
But he's right, it could be the combination of Intel + ATI that's causing the problem, they haven't discounted that in this review.
But most users would not turn off the superfetch or think to do.
So until the cause is really found then the facts as they are still stand as that's the normal circumstance of which Vista is run in.
And is the first time that im even aware of such a possible problem.
clearly this article is by trying to blame the cpu for short-commings in OS/games
if it was a short coming in the os or the game, then it wouldn't work better on the P2 cpu, but it does. My p2 system is superb and has been very smooth in everything.
THe point is, i7 will excell at times with raw power. Its a faster cpu, top fps will be with the i7, but average and minimum fps aren't based on the cpu, ever. They are gpu limits, the difference is, better faster more raw horse power cpu does NOT mean the motherboard, the interconnects, the responsiveness of the pci-e controller nor the chipset are faster.
When you're at a gpu limit, on the same gpu giving the gpu every single advantage to get extra fps is paramount, and that doesn't come from the cpu, when you AREN'T cpu limited, it comes from the apparently better architectural setup of the P2 systems, maybe its simply a better interconnect that they've had several years to learn from past versions and small tweaks and improvements. Is that really so hard to believe? Intel have been stuck on the old FSB for a LONG time and the new interconnect is just that, new, brand new, its a first generation and their first memory controller. They've intergrated a lot of new things and clearly, its somewhere the AMD systems are slightly better in.
I'd take a system with 30 min, 60 average and 80max frames in a game over a system that has a 20min, 62 average, and 110 max framerate. The faster actual cpu, JUST the cpu, is in the second system, in this case, the i7. But the faster system, giving the better experience is the AMD system.
i7 will always benchmark higher, it will never be good value for gaming and it won't provide the best experience.
Rypt, you're coming across as a fanboy, you read a review, which no where at all says the i7 is a slower cpu, but instantly react in this thread like Anandtech are bashing the i7, which they very clearly aren't.
A system doesn't have just an i7 in though, its a faster cpu, thats not where the problem lies.
I honestly thought when first reading thing thread title that they were comparing a Pentium II to current cpus, haha!
P2 chipset is the same as the P1 chipset, AM2+ so unless AMD royally messed up AM2+ for the past few years...
If i7 can bench higher, it clearly shows that there is no problem in how the CPU communicates with things, so perhaps this is just crossfire mis-behaving, woudl be interseting to try this exact same test with sli.
People are seemingly forgetting that ATI cards are optimised to run better on AMD hardware, as I said, this could be purely a Intel + ATI issue, it might not be repeated with an Nvidia card.
Thinking about it & what i have been reading on this forum with users who have switched from ATI to NV & said that NV card ran smoother seem to be on Intel mobos.
Prolly more likely down to the motherboard\memory\gpu combo interacting than the CPU.
I'd venture to say that Anandtech are talking balls, and it wouldn't be the first time. They aren't quite as technically minded as they like to imply.
See again you're posting something that makes no sense. I didn't say the p2 uses a different chipset. However AM2+ is not a few years old. They first had HT, on board mem controller and a different way of communicating across the board, what, 4 years ago, 5 maybe on 754 boards, 939, 940 boards, am2 and am2+ are what, less than a year old or maybe just over a year. Thats several iterations with YEARS of experience.
THe difference here is the P1 was slightly slower, it also had less cache than it needed and lower clocks than needed, we're talking about Anand comparing a 4Ghz p2, with a p1 at stock of what 2.4Ghz. Once you have enough cpu power, which they now have, it becomes about everything else.
Ati cards aren't optimised especially for amd systems. its a card, it needs data as fast as possible, it works within the pci-e slot. Theres something working slightly better, thats causing a tiny amount of quicker communication opening up the ability to get the card working at its maximum capacity letting it get higher min fps.
I can't find anything even close to surprising about AMD's 5 year old, matured, tweaked motherboard's communication architecture having some slight advantages to a 2 month old, brand new, never seen before first chipset new technology intel setup which still has 5 years of life in it that will no doubt be tweaked in the future.
I'll point out again that you first said, they are blaming the cpu(they didn't) for clear shortcomings in the OS/games, the fact is the same game/os worked better on the amd system, this completely disproves what you say. If it was a shortcoming with the software it would be the same with both systems, it clearly isn't.
Title of this thread should be PII Vs Q9550 V i7, I7 = smoother.
On 5 games the i7 was best for min/max and average,
One of the games the Phenom2 did well, was a perfect demonstration of a game that has poor crossfire results, the PII dropped from min 18 to min 16, and the i7 dropped from Min 20 to Min 16.
This whole clear the prefetch happened in 1 game out of 7, Company of Heroes - Opposing fronts. This game clearly favoured the Phenom II for minimum framerates. There is clearly something badly optimized in Company of heroes, its performance on both intel i7 and Q9550 platforms was poor. Of the 7 games this is the only 1 which showed the PII as the smoothest system.
So 5 games the i7 was the best all rounter, with the 9550 doing very well too, in 1 game (Crysis warhead) there was virtually no difference between the i7 and the Phenom II, results almost within margin of error. But the Q9550 did perform considerably worse on this test. Not a clear victory for the PII though, on the whole it looks like the i7 is the "overall" winner on Crysis warhead.
To be honest, I wonder about the results accuracy anyway, in COH the [email protected] had a minimum CF framerate of 90 V PII's 85, yet overclocked to 4Ghz the i7 only managed 85, while the PII managed 91. Infact i7 at stock 2.66ghz was almost within margin of error with the PII at 3.95ghz. Looks like their overclock wasnt entirely stable to me.
