Nice rig electronic dave, though id suggest turning your TRUE cooler so that the hot air vents out through the rear case fan, you shouldnt have any issues fit wise as this is how i set up mine in an eclipse.
Thanks guys - I should point something out about the difference of the Thermalright True heatsink mounting, as I'm probably in the minority with a AMD Phenom II X4 rig and most (if not all) Intel boards can have it this way...
excuse the long winded explanation below...
The Intel LGA775 mounting holes are symmetrical (i.e. perfect square) so you can mount the Thermalright True Black either way round (so its either setup my way or the other way round as setter has suggested) which is what I intended to do (having it blow warm out straight towards the exhaust fan)
However upon assembly I discovered that the AM2 socket mounting holes are not symmetical and the backplate is rectangular - this means you can only mount the Thermalright True Black one way (in line with its included adapter) - low and behold it would have to be the illogical way round wouldn't it?
I was a bit miffed as I had assumed, having own several of these type of heatsinks, would be mounted as setter suggests and is possible on the Intel LGA775
I suppose this is what you get for going AMD!
I'm sure the heatpipes must work better or something instead to compensate for this?
I have the heatsink fans (1 Hiper / 1 Sharkoon) on Q/Smart Fan (Performance) and both hover at ~1300rpm, with the rear exhaust at a slightly slower 1200rpm (have replaced with an Antec 3 speed fan) as the PSU does take a little too...another Hiper at the front helps drag cool air in to the GFX card area
The cables have been tidied a great deal more since the photos where taken, but because everything is black they are difficult to spot anyway
