Does anyone pull air through their rad and a general tubing question?
I've got a Thermochill PA160 and currently have the fan attached to my case then to the shroud and air is pushed through the radiator.
I was looking at tidying up my case a bit to improve airflow and saw a mounting kit for the rad but this would mean bolting it to the case with the shroud on the other side and pulling air through it.
Is one method better than the other or will the net airflow through the rad be the same?
Also I've always used tygon tubing but am adding a NB block to the loop and for easyness was looking at ordering some XSPC 1/2" tubing along with the Swiftech MCW30 block from OcUK. I take it there wont be much difference between that and the Tygon?
