OCZ Blade - 2000MHz 6GB Tri Channel Kit - £369.99 Inc VAT.
The Blade Series Triple Channel Memory kit is the latest maximum-performance RAM designed specifically for the Intel® Core™ i7 processor / Intel® X58 Express Chipset. At DDR3-2000, CL 7-8-7, the Blade Series harnesses industry-leading speeds at the low voltage required to safely run Core i7’s triple channel mode. With the ideal combination of all the factors that formulate the ultimate memory solution— density, speed, latency, and an effective new cooling design—the Blade Series is guaranteed to please enthusiasts looking to take the hottest Intel platform to new heights. The Blade heatspreader aims to enhance heat dissipation to improve the longevity and stability of the modules while keeping a sleek, low profile. The new propriety design has numerous channels that increase the surface area to more efficiently offload heat away from the memory chips and PCB. Push your gaming or overclocking rig to the extreme with the superior thermal solution and unmatched speeds of the high-end Blade Series memory modules. Wheter seeking maximum frame rates in the latest PC titles or yearning for the highest benchmark record, the Blade Series was developed for gamers and overclockers looking to make the most of their high-performance systems.
- 2000MHz DDR3
- CL 7-8-7-20
- Available in 6GB (3x2048) Triple Channel Optimized Kits
- Unbuffered
- 1.65 Volts
- 240 Pin DIMM
- Pure Aluminum Heatsink
- OCZ Lifetime Warranty
Buy Now.
- 2000MHz DDR3
- CL 7-8-7-20
- Unbuffered
- 1.65 Volts
- 240 Pin DIMM
Buy Now.
