Those cassette adaptor things...
19 Oct 2002
Jupiter
...do they work very well, or does it sound totally crap?
I've got the standard Ford 5000 unit in the Mondeo, and i've got a trip to Scotland this weekend so i'm looking to use an MP3 player.
Theres loads on eBay for £2 - £3 each so hardly expensive, just wanted to know if anyones used one before, and if they are worth buying/using, or sticking to CD's!
Cheers,
Phil.
2 Mar 2004
SE England
Worth a shot - depends on the HU. Some of mine refused to accept it as a playable tape and would stop it automatically after a few seconds, or reverse it and then stop.
Worked just fine in some instances though, bit quiet or grainy but much, much more preferable than not at all! :)
15 Jan 2005
UK
I got one from Tescos.. Its very good, I use it with my phone. No distortion at all, its just as if the phone is plugged into the stereo. If you find that at first it sounds a bit garbled try rewinding the tape.
Caporegime
19 Apr 2008
Essex
I had the standard Ford stereo in my car and it accepted it fine, probably due to it's cheap mechanical nature :p i didn't find any grainyness at all, it was just a couple of notches quieter on the volume.
13 Mar 2007
Cambridgeshire
Also have a Belkin one, which works fine for me. I've also tried one of those short-range FM transmitters which was pretty dire, far worse quality-wise than the cassette.
20 Jun 2005
London..
One of my mates has one for his Lexus IS200 Navigator as its CD player is busted...i think he paid a fiver for it and it's pretty decent for what it is...
Jez
Jez
Caporegime
18 Oct 2002
They seem to work absolutely fine, i guess it depends on the quality of the tape deck in the car.
27 Nov 2004
North Beds
I found the same when I used one many many years ago. Not seen a cassette player in a car for years.
most BMWs bar the current shapes have them as well as a 6 cd changer. Generally the ones without the changer got a single cd in the dash.
My car has the harman kardon stereo upgrade and still has a tape deck! lol
