Best Mount for a TomTom One
23 Feb 2004
Manchester
Looking for a mount for my TomTom One which doesn't give away the fact that you own a satnav. The vent version isn't a contender from what I've seen.
Suggestions?
Nothing really, looking for an alternative mount which doesn't necessarily attach to the windscreen and leave an obvious mark.
You could try those discs which are basically a coaster stuck to the dashboard to which you stick the sucker mount of your TomTom.
you've got a couple of problems here
1) you want a removable mounting. having a cradle in the car is as big a draw to thieves as a sucker mark on the windscreen.
So it has to removable to deter thieves
2) you have to balance the ease with which it can be removed, with the strength of the mount. It has to be strong so has to grab hold of something. If its not going to mount to the vents (which as you say arent strong enough) what else are you going to mount it to ?
I cant see anything better than sucker mounts or vent mounts that still retains the ease of removal.
Just wipe the mark off tbh.
