You need to cut the magnet off the back of the speaker.
I'm drawing the die dots on the coloured bits, but can't get it to open. Should I be doing something else? How do I know which way to draw 6, for example?
why can't i open the ****ing safe?
do i have to stop exactly on the numbers first time? because that's impossible to guess all 4 numbers when its spinning
For drawing a six you click the two outer columns on the keypad and leave the middle one blank.
i got the code for the safe but how do i do it?
ive never used a safe
I've got loads of items now and in reasonably quick time too. Cant see which wooden floorboard the gold bar should go on. Laptop screen makes it hard to see
Where is it?
If your code is something like 42R34L25R52L
Then you click the safe dial (click the right hand side for right left had side for left) 42R means starting from zero, click the right hand side until you land on 42, then click the left hand side until you land on 34, right until you land on 25, left until you land on 52. Hope that explains it ok..
If you look at the wall the suitcase is at, click the bottom left corner of the screen by the floor. Should take you into the corner of the room.
