I am currently running a Dell Dimension 2350 2.6GHz with 768MB of DDR RAM and, after four/five years of working to a satisfactory level, it is now showing its age and in dire need of replacement. Unfortunately, I’m not flush enough to be able to splash out on a top-of-the-range unit and so I’m looking to build one to a specification barely sufficient to cover my needs.
To this end, the programs I need to run are: Autodesk AutoCAD, Autodesk 3ds Max, Adobe Photoshop CS3, Adobe Lightroom. I don’t really play games but I’d like a machine which can admirably handle Football Manager and The Sims series. I don’t play Call of Duty or any majorly graphics-intensive games so there is no need for the latest-and-greatest graphics card. I will be using Windows 7 when it arrives and, until then, will be sitting on XP.
I will be starting from scratch. Components like the monitor, speakers, keyboard and mouse can come across from my old PC but I need a tower and everything that goes into it. As I’m a complete amateur with computers, you can imagine the trouble this poses for me. This is even more so given my budget.
So far, the setup I'm looking at is:
Asus P5Q MoBo £85
Intel Dual Core E5300 £50
Corsair TwinX 4GB RAM £50
Corsair CX400W PSU £40 (concerned that this may be loud?)
I'm undecided on the GPU as I need dual output but the Radeon HD4670 doesn't seem to feature this. Also, what difference does it make getting a Sapphire or Asus GPU? And if a 1GB GPU is the same price as a 512MB, why not get the 1GB?
My next query is in relation to the HDD. I'm going to run a massive 1TB storage drive and then have a smaller OS drive. The HDDs I can't choose between are below - they all come within £5 of one another:
- Seagate Barracuda 7200.11 1TB
- Hitachi Deskstar 7K1000 1TB
- Samsung Spinpoint F1 1TB
- Maxtor DiamondMax 22 1TB
I'll decide on a case at a later date but I won't be spending much on these - I just want a plain, decent-looking black one without flashing LEDs.
Can you offer me any feedback/recommendations please? I'm lost in all of this technical detail!
Thanks!
Asus P5Q MoBo £85
Thanks!
