You really do that?![]()
No
You should see the grin on my face.
P.S hows the 5?
That can't be normal.
My old 5 hasn't drunk/burnt a drop in 5k miles, it's done 111,000 and thats with 0w40.
Opie oils can be good for the harder to find oils and has a wide range, they offer discounts (30% last month) quite a bit which more than covers postage, and Mobil F/S 0w40 is £23 (5L)
Both her TDi and my RS4 take the same oil and we never really buy it sensibly. I put a litre in mine today as when I checked it was just on the minimum and it does like to drink the stuff, around 3 litres between services presently.
I topped up mine with a litre of this stuff, it started using oil a lot quicker was visibly burning it in the exhaust.
Changed the oil and it has stopped smoking. It seems to have a very light base oil mix making it very volatile. If you are using a lot of oil (which it sounds like you are) it may be worth trying something else to see if it improves things.
What do you use?
Good point, my original point in factThink you missed the point
Running engines in is pretty much best done on only reasonable quality mineral oil. If you run an engine in on super spanky fully synthetic you end up with poor compression ring seals as it prevents the rings bedding to the honed bores properly
I used to work in a motorfactors for a few years, around 2007 iirc the price oil literally doubled in a matter of months. Even the cheapest 20w50 more than doubled in price, along with batteries, anti-freeze and copper brake pipe.
because owning and running a car clearly wasnt dear enough
absolutely. ive noticed how the cost of almost all consumables have gone up. the raw material price cant have gone up for every material under the sun
not all at the same time, its just highly unlikely. what about asda etc pegging their petrol and diesel prices at 99.9p and showing how other outlets were just over inflated.
i see the cost for other things as much of the same
Unless it's a rotaryI'm not saying engines that use oil are broken, but there is something wrong if it is using a litre every 1k miles.
have a look for Motul 8100 eco energy
im sure i found this for £26.99 inc VAT for 5l....and its ester based synthetic or whatever that means?!
i dont know if its the *best* but surely better than halfords own?!
