you mean 2-2 ?
i think it depends on what kind of character he has. If he is just meleeing the bugbears then no no no no !! It will take you too long to kill them . Your weapons and armour need lots of repairing and basically its a lot of effort.
If you want souls quick when you are low level Alex Get soul arrow. Up your magic. Goto 1-1 take out the blue knights and take out red eyes knight for guaranteed 2k minimum. (the bugbears sometimes only give 650 ish each) You will end up with over 3k each run on the red eye knight because you kill enemies on the way to him.
Heres how you kill red-eye when you are low level. Equip thief ring. inch closer to him until you can target him - hopefully thats before he can run at you. Start shooting at him with soul arrow AND backing away because he will be charging you. On your 3rd or 4th hit with soul arrow you will stagger him and take off a big amount of his hp.
If you get too close you'll be dead - if you can get the purple flame shield that helps a little with blocking his attacks but basically if he is close enough to melee you you'll be dead....
6 minutes each time but i took a shortcut that opens after you kill the boss of 1-1.
Yeah 2-2, but your probably right 1-1 would be better especially as the red knight gives you 2K, shame all the others are so low. On the other hand 4-1 isn't bad for farming souls as the skeli's should give you a fair few souls especially the black ones....
Temple Knight level nine with a halberd and cutlass lol
You really do need to level your character up, maybe run 1-1 a few times before tackling any other level's. Alternatively consume the 1-1 boss's soul for 1400 souls which you give u a couple of level's? U do know u can consume all soldier/hero souls u find in the level's for addition souls?
