System file checker and XP disc created in Nlite?
19 Dec 2006
UK
Need to run system file checker as I'm having a few issues, however the disc I used to install was a custom created using nlite and as such is called WinLite, system file checker as such wont use it, any way around it other than recreating another disc and renaming it?
so you don't have the original disk at all? :confused:
It's here... somewhere lol :(
don't use SFC on an nlite install, it will go mental
what issues are you having?
Only used nlite to slipstream SP3 and RAID drivers, all else was left alone so it shouldn't go mental I'd have thought...
Ayway, main issue is an empty computer management MMC, have scanned for all the usual nasties and am pretty convinced it's due to me having had issues with the RAID controller which has wiped out parts of the registry before now and a manual restore has had to follow.
Ahh, I assume you'd cut things out from it
Try creating a new user account and looking at mmc in there..
