Recommend me a 16 port Gigabit Switch
12 Feb 2004
Manchester
well my 3com 16port 10/100 has just died, so looking to upgrade to a gigabit
any recommendations? i didn't realise they still quite dear!
one im looking at is the netgear GS116 which also has lifetime warranty which is probably what you pay for in the £125 price tag!
any others? no named brands ok these days?
wij
wij
27 Dec 2006
I'd go for the ProCurve over the Netgear offerings any day too, but AFAIK they don't do a 16 port GigE switch its 8 or 24 on their cheaper lines.
Still you can pick up the ones linked to above for a lot less if you hunt around.
OP
12 Feb 2004
Manchester
just been looking at them, the 1700 only has 1 gig port, the rest are 10/100, is that right?
however the Procurve 1400 is a 8port GigE and can be had for £50.
maybe 2 daisy chained, hmmm!
wij
wij
27 Dec 2006
I have two of the little 1400 8 port GigE switches in my house, one upstairs one downstairs - decent build quality and all that, the only thing that I dislike is the external PSU but at the price (if you look you can find them lower than £50) they are hard to beat.
If you want a 24 port GigE one then you need to be looking at the 1400-24G which is a 1U 24 port GigE switch that comes in at around £150 mark.
A bit of a premium over two of the 8 porters but it gives you a neater system and also a few extra ports which never hurts.
13 Sep 2003
Glocestershire
We have loads of HP ProCurve kit where I work, ranging from a dinky little 1400-8G unto 5406 (with about 120 ports).
It's rock solid, not had to RMA anything in the last three years.
Don't bother with the 1700, I really can't see you needing a managed switch. Either two 1400-8g or one 1400-24g will do the trick.
OP
12 Feb 2004
Manchester
thanks guys
not "many" places sell these procurves, a few of the common online stores have them,
i think il get one to start with and take it from there.
is the procurve 1400-24g fanless?
18 Oct 2002
Ironing
I don't think so, the 1800-24g certianly isn't. It's not too noisy though. We are using one sat on someone's desk and they havn't compained about the noise.
I thought the newer ones were fanless? I remember reading that the model number that ends in B is fanless, but the one ending in A isn't.
OP
12 Feb 2004
Manchester
Do you mind if I ask, is this for home use?
I'm yet to fill my 5 port :o
yep, for home use, considering how many networked device i have in the house a 16 port is a must. Pc in every room, many consoles, network media tanks, NAS etc :eek, think i must cut down to save on eleccy!
im still on the hunt, why on earth dont they do a 16 port Procurve!!!!!! 8 or 24!
