Cooling Advice
22 Sep 2009
I was thinking of purchasing an offer on Overclockers:
Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz @ 4.00GHz......
The only problem is with the fan, Noctua NH-U12P SE1366 CPU Cooler
(Socket LGA1366). I am fairly sure it will not fit into my case. The external
width of the case 18.5 cm. (internal measurement some what less)
I was looking at the Corsair H50 High-Performance CPU Watercooler (Socket
LGA775/1366) but this is not the correct socket number.
Can any one advise on a suitable cooling system within a similar price region
of £60.(or below) that will fit?
19 Dec 2008
Eh??? the i7 is socket 1366, the H50 supports socket 775 & 1366, so this will plug straight into the board,
Edit- I mean you will probably have to use the back plate to fit it to the motherboard
11 Sep 2008
Co. Durham
The H50 LGA1366 will fit the Ocuk Intel Core i7 920 D0 Stepping Bundle just fine mate
