Will an Intel Atom Dual-Core 330 CPU be quicker than an AMD Athlon 2800?
Man of Honour
29 Mar 2003
Stoke on Trent
Thinking of upgrading one of my daughters PC's with an ITX system but didn't want to go down in speed on the processor.
I know it's a lot newer by at least 5 years but the 1.6ghz speed bothers me.
Thanks
12 Mar 2009
I have an Athlon 3000 under the desk (old computer I use for testing networked code and as a backup) and it completely destroys the Atom 330 in my netbook at everything I use it for.
18 Oct 2002
South Manchester
The Atom runs at about the same speed clock for clock as a late Pentium 4 if you average out the benchmarks. Pentium D 1.6GHz anyone?
I'd build something with a Pentium E/Core 2 instead.
13 Dec 2003
UK
its easily better than a athlon xp 2800 i assume you mean?
but i wouldnt recommend it over a custom system tbh
pick up a cheap intel pentium dual core e series and work from there
