Right after browsing this side of the forum for the past few weeks or so, ive decided the ford focus is the car for me, 1.6 more specifically.
Now im going to be a first time driver, currently have a full time job, probrably going to be using about 12 miles a day possibly more if i sometimes decide to do the full commute (30miles a day) , and im 23. Budget wise ive got 5k but im gonna have a guess and say first car, dont spend that much ? Incase i smash the thing to pieces
Im liking the newer shape focus's 05 onwards. But a lot of the ones im seeing are starting from about 4.5k, milage around 60k+ , is that about right or ?
Or should i just go cheaper 2002/2003 older shape possibly a bit higher spec but coming to overall cheaper total. Is there any other major diffrences from the 05 onwards ?
Also what milage should i look around when after a 2nd hand car, specifically a focus.
Appreciate the helps. cheers (Novice) Bailes
