rofl yep tbh its the funniest way to play - after 5 or 6 kills in a row i begin to giggle like a schoolgirl
I think its lame as hell but i must confess i use that build sometimes
same goes for akimbo 1887s
if you cant beat them join them...
Ok what about this then...
Getting really ****ed off with the lag
I tend to watch the kill cams and they get me even more worked up.. on my screen before I died I sprinted behind a wall. On the killcam I got blown away before I even reached the wall. It doesn't necessarily matter if you react faster than the other guy.. it seems largely down to ping and if your hits register.
I'm close to rank 70 and I feel compelled to get there but I doubt I'll bother playing it after that.. it just winds me up!
No hack, its just the 'Witch' build.
Primary: Sniper (for Camo)
Second: Pistol + Tac Knife
Perk1: Marathon Pro
Perk2: Lightweight Pro
Perk3: Commando Pro
Its very easy to just go charging around, flank behind the enemy team and knife them all.
I've had several 11+ kill streaks from using that build, works better on some maps than others (for example it doesn't work very well on open maps like Wasteland as you get picked off from miles away).
Does the Tac Knife make much diff, can't be arsed trying to get 50 headshots with hand gun.
no one on the PC side will pay a subs. to play an fps game... dumb console gamers might... which means future COD games may not even make it to the PC... which hopefully means a more enthusiast led project more intouch with PC gaming gets a look in.
I uninstalled this, reinstalled cod4 and played it for 4 hours last night.
All I can say is cod4 >>>>>>>>> cow dung >>>> mw2
This is exactly how I feel. I'll get 70 then go back to COD:WAW.
The whole running behind a wall and still getting killed is so annoying! I'm not talking about bullet penetration, I'm talking about the killcam showing me die before I get behind the wall, even though on my screen I was well behind it!
Yeah, it happens so much more in this than CoD 4, infact, it always happens in this, if you retreat behind a wall you will die, and not due to penetration.
Baffling.
(Edit: I thought I was on the console forum, bizzare that this happens in all versions, I'm starting to think it's coded in for some reason :/ )
of course in this game you're always suffering a huge lag spike so it happens much mopre
