Username = proof?
ejr, you aren't being serious are you?
You are basically saying Sacha doesn't know what he's talking about because he only registered on OcUK's forums in Septemeber?!?!
Where in gods name did you pull that out of?
That is retarded, seriously.. you've trashed the OP's thread as well in the process..
It's clowns like you who ruin this forum.
Like bifday already said, just ignore this fool sacha, you don't have to prove anything to him..
In short the settings posted feature internal contradictions and impossible to set values.CPU Ratio: 21 #requires turbo mode to be on
Base Clock: 200
DRAM Frequency: 1603 #would be x6 or x8 bsck, i.e. 1200 or 1600. Not 1603
UCLK Frequency: 3208 #likewise, integer multiples of bsck only
QPI Link Rate: 7218 #and again
CPU Differential Amplitude: 800 mV #probably right, but is board specific
CPU Voltage: 1.23750 #chip specific, probably underestimated for 4.0
QPI/DRAM Voltage: 1.35 #chip specific, probably overestimated for 4.0
DRAM Voltage: 1.65681 #My board offers 1.64 or 1.66V. This is six sig fig => unlikely
Hyper-Threading: Off
Turbo-Mode: Off #yet you've said a multiplier of x21
Load-Line Calibration (LLC): Enabled
Disable C state
Disable CPU spread spectrum
Disable PCI-E spread spectrum
Disable CE1
Disable TM function
You may need to raise your CPU voltage a bit from what I have shown but these settings should give you a good start.
You obviously no nothing about this M/B or ASUS products, for once get a life and end this now, you two have totally corrupted this thread and started to bring another respected forum into disrepute, I ask once again for an admin to now close or clean this thread because two people that know nothing have nothing better to do than say things they know nothing about.My input on the sasha vs ocuk debate
@Sasha by all means give a reason why the settings suggested make no sense whatsoever, otherwise I'm going to have to agree with the person who said username is not proof of identity.
@The OP, i7 overclocking is fairly straightforward. Set uncore multi to double ram multi, or slightly over. x16 is a good start. qpi multi to x32. Ram multi to x8. Turn off the various power saving options.
Set ram voltage to 1.65V, qpi to 1.25V, vcore to 1.2V. Increase bsck then stability test, again and again until the stability test fails. At this point you may need more vcore, or more qpi, or lower temperatures. Try the first two, if neither helps come back here or call it a day.
That should be good up to 200 bsck, after which things get harder. If your cooling isn't good enough things will get hard before then.
Still.....no one has explained why HT should be turned off. I know it provides only a small benefit, but if you're the extreme overclocker you are sacha35, surely you can provide some evidence stating your reasoning behind it?
I recognised your username (have seen you featured on Custom PC mag and on HWBot) so was expecting some reasoned, in-depth, advice. Instead you just went off on one. Chillllllll......
If an admin can clean this thread up it would be much appreciated as this has gone right of the topic
, Helpful chaps the benchtec guys.hi mate - good to see you over here
the thread just needs to calm down, no point me taking action
please bear in mind that a lot of people looking for overclocking advice on these forums are not using high end/extreme cooling so may need to take the 'babysteps' approach to overclocking and not just wade in at 4.2+ immediatly
i see what you mean about 4ghz being the norm all day on air [ive done 3000+ 4ghz air overclocks] but you need to remember that most people havent got much experience and many dont ever read the sticky threads that explain HOW to overclock
my recent overclocks have been pretty high but generally have HT off
i leave it on for 24/7 as do most people [even though i dont really need the HT stats that i have access to from my chip]
OT
some impressive results you have there
were they dice/ss/ln?
I run similar settings that sacha posted on my rampage gene
i however use a 20 multi for 4ghz oc i have HT on and i run a slightly lower vcore.
its a good place to start if your unfamiliar with i7 overclocking.
Edit sacha have you attended an i series LAN events ? If you have ive met you, Helpful chaps the benchtec guys.
