I'm running Windows 7 Professional 32-bit and my system has 4GB RAM like Windows XP do I need to add the /PAE or /3GB switch so applications can use 3GB or am I confused?
Which command/switch would I need to apply if needed?
The /3GB switch simply allows applications to allocate 3GB of user-mode memory, and only 1GB of kernel-mode memory. Normally, the balance is 50:50 at 2GB user-mode and 2GB kernel-mode. This is because this is the ideal balance in 32-bit Windows. The /3GB switch exists for certain edge cases, such as when running SQL Server on a 32-bit server.
/PAE mode is for supporting more than 4GB of physical memory on a 32-bit machine. It is only functional on certain Windows Server releases.
Basically, you need to upgrade to Windows 7 x64. There is no alternative.
Both the /3GB and /PAE switches can be considered temporary "hacks" of their era (when x64 processors didn't exist). That's why x64 releases of Windows no longer support these switches at all.
Windows 7 has XP Mode (basically a 32-bit VM of XP Pro that is more neatly integrated with the host OS than a regular Virtual PC 2007 VM is).
/USERVA switch is unrelated.
There are no boot switches which will allow you to use the full 4GB of memory. The issue is that there is a 4GB virtual memory address space. So whilst the vast majority of this is mapped to your physical memory, unfortunately some of it must be mapped to other devices such as your graphics card.
A system like that in your signature should be running Windows 7 x64. Otherwise it is not going to ever reach its full potential.
