Heya, I've got a Lian Li PC-A05b which came with two 120mm case fans each rated like so:
RPM - 1500
Airflow - 56 cfm
Noise level - 24.7 dB(A)
I was just wondering if it's safe to assume that any branded fan from the likes of Scythe, Noctua, Akasa, Noiseblocker and so on will be quieter than these Lian Li ones as long as they are of a lower rpm? Take the 1200rpm Scythe Slipstream for example:
RPM - 1200
Airflow - 68.5 cfm
Noise level - 24 dB(A)
Is it really plausible that it will offer such drastically higher airflow while managing to be quieter?
RPM - 1500
Airflow - 56 cfm
RPM - 1200
Airflow - 68.5 cfm
The Apache does look interesting though!
