- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys
We have the first stock in the UK of the latest CM-690-II Advanced Case from Coolermaster. The CM-690-II offers great new features including watercooling support, SSD Support and more.
Coolermaster CM-690-II Advanced Case - Black @ £89.99 inc VAT
The CM 690 II Advanced raises the bar again with practical improvements over the top-selling CM 690. The spacious mid-tower will keep enthusiasts happy with room for up to 3 vga cards, high-end CPU coolers, top or bottom mount water cooling radiator and 1.8"/2.5" drive adapter. It also features much improved airflow with oversized mesh and enough space for up to 10 fans. Maintenance will be a breeze with the tool-free drive bays, new cable management and CPU cooler retention hole.
- Dimensions: 214 x 511 x 528mm
- Motherboard Compatiblity: ATX, Micro-ATX, Mini-ITX
- Room for 120 x 240mm Radiator inside the top and bottom
- External SATA HDD dock
- Includes SSD Adapter
- Cable management and CPU retaining holes for easy maintainence
- Support Tri-GFXs
- 4 x 5.25" Drive Bays
- 7 x 3.5" Drive Bays
- I/O Panel: USB2.0, 1 x eSATA, 2 x Audio
- Front Cooling: 1 x 140mm Blue LED Fan
- Rear Cooling: 1 x 120mm Fan
- Top Cooling: 1 x 140mm Fan
- Bottom Cooling: 2 x 120mm Fans (optional)
- Right Side Cooling: 2 x 120 or 140mm Fans (optional)
- Left Side Cooling: 1 x 80mm Fan
- HDD Cage Cooling: 1 x 120mm Fan (optional)
- VGA Holder: 1 x 80mm Fan (optional)
Only £89.99 inc VAT.
ORDER NOW
- Support Tri-GFXs
ORDER NOW
, and not too much ££ either.
