4 pin fan to molex cable?
Your spec says you have 2 already, bad memory eh?
I bought one earlier this week and though I don't have it here I'm 99% sure it did not come with a molex adaptor. The closest that OcUK have is this, though I beleive I've seen a smaller version (1 or 2 fans instead of 4) in a highstreet electrical retailer. Cockney ryming slang for it would be 'Charlie Chaplin's' :)
if you snip off the sides of the fan connector you have listed here you will be able to fit a four pin fan onto it, the fourth unused pin would be the power adjusting pin which doesn't work when connected to a four pin molex as it is controlled by the motherboard.
Hmm. This is good to know. Think I might butcher the fan that came with my stock cpu cooler and use it to blow air over my IGP heatsink.
Yep, done this myself!
